EVAP Solenoid
Alright so I am drawing my vacuum/boost from the EVAP solenoid's output under the intake manifold behind the throttle body. In an attempt to keep the EVAP system functioning correctly I also routed it back to my vacuum block. The vacuum manifold distributes vacuum/boost to my BOV,boost gauge and EVAP solenoid. Will this cause any problems? I can't see why it would since under vacuum any fumes released by the solenoid should still be drawn to the vacuum source which is the same as it was.
Thanks in advance, Ryan Last edited by Ryan P; 06-25-2014 at 11:05 AM. |
| BRZ/FR-S Gunma plant aware of these Solenoid, Cam, CEL problems? | 07stealth350z | Issues | Warranty | Recalls / TSB | 24 | 11-18-2015 08:44 PM |
| DIY clamping the evap vacum ports under the manifold!! | charged86 | DIY (Do-It-Yourself) Guides | 9 | 04-08-2015 07:56 PM |
| Prodrive 3 Port Boost Solenoid | rb6freak | Engine, Exhaust, Bolt-Ons | 0 | 06-18-2014 01:16 AM |
| Evap lines under the Intake Manifold - Easier fix? | protpibe | Forced Induction | 7 | 05-13-2014 01:11 PM |
| Gearshift solenoid issue | Gotchaman | Engine, Exhaust, Transmission | 0 | 12-30-2013 06:32 PM |
