Old 05-15-2013, 02:18 AM   #15
Hanakuso
Got it setup tonight. Hero 2 with wifi pack.
Hanakuso is offline   Reply With Quote
Old 06-02-2013, 10:30 AM   #16
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Originally Posted by Apocalypso View Post
Pretty cheap and simple GoPro tow hook mount. You need three things:
  1. Tow hook (check your trunk)
  2. GoPro handlebar mount: http://gopro.com/camera-mounts/handlebar-seatpost-mount
  3. Large nut on the tow hook to keep it from going in all the way. I used a 3/4", which is just big enough to slip past the threads, but not slip all the way down the tow hook.
What you get:
Also, if anyone is curious, I have this mic http://www.audio-technica.com/cms/wi...eca17168eef6f/ routed up through the tow hook opening and into the engine bay by the battery. Worked like a charm!
howd you get your video to not sound completely like wind
Mathewgzlz is offline   Reply With Quote
Old 06-02-2013, 10:44 AM   #17
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
BatStig is offline   Reply With Quote
Old 09-24-2014, 01:46 AM   #18
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by Sevs753 View Post
I did this as well. The problem with the BRZ is that the tow hook sits too far in, even with the nut. The camera either has to be pointed slightly up or will be slightly crooked (its crooked in this picture). It shouldn't be an issue if I just use one of the little extensions.
Found a solution to this.
Instead of the 3/4 nut, use a 3/4 fender washer (I believe the bin number is 3260).
It is cheaper than the nut by far ($0.47 and I used one), and allows me to use the towhook on the BRZ without it being crooked.
I did a test fit and got the results in the pics.
Haven't actually driven with it though, so I can't tell you if it shakes or anything. Should be fine though, as the towhook is tight.
FYI - I have the Hero 3+, which is a bit slimmer - but there is still plenty of room behind the camera, so I suspect this should work with all GoPros
daiheadjai is offline   Reply With Quote
Old 04-19-2015, 11:45 PM   #19
elyugi1
Drives: raven black
Why you guys use a washer or a nut for? Im a noob sorry
elyugi1 is offline   Reply With Quote
Old 04-20-2015, 03:05 AM   #20
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Because without it, the stock tow hook screws too far in and there isn't enough room to mount the go pro onto the tow hook.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 07-19-2015, 05:54 AM   #21
Mingo
Drives: 2015 BRZ Limited
not to resurrect an old thread, but i just found that using the roll bar mount doesn't require any washers on the stock tow hook. just gotta turn it in all the way until it stops at the horizontal position and clamp it on the big "O" works pretty well.
Mingo is offline   Reply With Quote
PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available Mrc@ptuning Audio/Visual, Electronics, Infotainment, NAV 23 04-18-2015 09:43 PM
Ptuning tow hook camera mount Doborder Tracking / Autocross / HPDE / Drifting 35 12-23-2014 05:06 PM
PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available Mrc@ptuning Tracking / Autocross / HPDE / Drifting 4 04-30-2013 01:09 AM
New Hotness: Proto License Plate Camera Mount for GoPro Cameras! RallySport Direct Announcements, Contests, Giveaways 3 03-27-2013 09:29 PM
My Free tow hook license plate mount mact BRZ First-Gen (2012+) — General Topics 15 03-23-2013 01:33 AM
