Old 05-05-2013, 10:51 PM   #1
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
DIY: GoPro tow hook mount
Pretty cheap and simple GoPro tow hook mount. You need three things:
  1. Tow hook (check your trunk)
  2. GoPro handlebar mount: http://gopro.com/camera-mounts/handlebar-seatpost-mount
  3. Large nut on the tow hook to keep it from going in all the way. I used a 3/4", which is just big enough to slip past the threads, but not slip all the way down the tow hook.
What you get:
[ame="http://www.youtube.com/watch?v=pKP-zfJQK90"]Scion FR-S at Mosport DDT - YouTube[/ame]
Also, if anyone is curious, I have this mic http://www.audio-technica.com/cms/wi...eca17168eef6f/ routed up through the tow hook opening and into the engine bay by the battery. Worked like a charm!
Last edited by BatStig; 05-07-2013 at 04:18 PM. Reason: New pic & nut size explanation
BatStig is offline   Reply With Quote
Old 05-05-2013, 10:56 PM   #2
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
NICE, so a 3/4" nut works huh?
Cool I'll give that a try
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 05-05-2013, 11:00 PM   #3
BatStig
Some say.....
BatStig's Avatar
3/4" is a bit bigger than the tow hook's thread, but it did the job.
Old 05-05-2013, 11:16 PM   #4
ft86me
ft86me's Avatar
Drives: 2013 FRS
bravo good sir! pretty awesome!
ft86me is offline   Reply With Quote
Old 05-06-2013, 04:18 AM   #5
JiB
JiB's Avatar
Drives: GT86
awesome idea, cheers!
ps. you were flying around that track!
JiB is offline   Reply With Quote
Old 05-07-2013, 03:27 PM   #6
BatStig
Some say.....
BatStig's Avatar
Thanks, man! :happy0180:
Mosport DDT is a fun little twisty track that our cars were built for. I learned that day what lighter/wider/stickier wheels & tires can do for this car from another FR-S in my group. Once he got those things warmed up (it was hovering around freezing all day) all I could do was get the hell out of his way!
Old 05-07-2013, 03:50 PM   #7
Hanakuso
Do you have any closer pictures? I'll probably go this route.
Hanakuso is offline   Reply With Quote
Old 05-07-2013, 04:19 PM   #8
BatStig
Some say.....
BatStig's Avatar
Updated OP with pic of whole setup and revised nut size choice explanation.
Old 05-07-2013, 04:53 PM   #9
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
This is a great idea!
The footage turned out great and for $20 its the most economical solution I've seen so far.
Thanks for the details on how to make it work!
Old 05-07-2013, 05:01 PM   #10
Hanakuso
Thanks for the update. I just ordered one on amazon for $19. I'll probably play around with it by this weekend.
Btw, does the Gopro need a battery powered mic? I have a clip on mic that doesn't use batteries. It's meant for computers.
Old 05-07-2013, 06:09 PM   #11
BatStig
Some say.....
BatStig's Avatar
Don't quote me on this, but I don't believe a GoPro requires a battery powered mic. I went with this one because I found a whole mess of videos online with this mic, plus it has a 20' cable which means it can be mounted anywhere. Batteries are cheap too.
As soon as I purchase a new exhaust I will be trying the mic mounted right by it.
Old 05-07-2013, 11:08 PM   #12
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Battery powered mic is highly recommended from what I've searched (but not matter what the stock built in microphone is horrible!). A lot of people seem to like the Audio Technica PRO 24CM (~$60-$70):
[ame="http://www.youtube.com/watch?feature=player_embedded&v=pN_CyTfINOA"]GoPro HD Hero2 with external Audio-Technica Pro-24CM Microphone - YouTube[/ame]
[ame="http://www.youtube.com/watch?feature=player_embedded&v=ai_E87u7CfM"]2008 C6 Corvette Kooks Headers Z06 Mufflers M2W - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=EMWVjJYV5Gw"]GoPro Hero2 / Audio-Technica Pro24-CM External Microphone - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=nKuyhOGEPdc"]Audio Technica Pro 24-CM microphone with GoPro Hero2 test - YouTube[/ame]
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-09-2013, 03:08 PM   #13
BatStig
Some say.....
BatStig's Avatar
I remember seeing that C6 videos when I was searching for a mic. It definitely sounds good. My wallet dictated which mic I should buy. He's bossy.
Also should mention for anyone shopping around to make sure you get a mic with a stereo connector. If you use a mono connector you will only get sound in one channel.
Old 05-13-2013, 12:04 AM   #14
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
I did this as well. The problem with the BRZ is that the tow hook sits too far in, even with the nut. The camera either has to be pointed slightly up or will be slightly crooked (its crooked in this picture). It shouldn't be an issue if I just use one of the little extensions.
Sevs753 is offline   Reply With Quote
PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available Mrc@ptuning Audio/Visual, Electronics, Infotainment, NAV 23 04-18-2015 09:43 PM
Ptuning tow hook camera mount Doborder Tracking / Autocross / HPDE / Drifting 35 12-23-2014 05:06 PM
PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available Mrc@ptuning Tracking / Autocross / HPDE / Drifting 4 04-30-2013 01:09 AM
New Hotness: Proto License Plate Camera Mount for GoPro Cameras! RallySport Direct Announcements, Contests, Giveaways 3 03-27-2013 09:29 PM
My Free tow hook license plate mount mact BRZ First-Gen (2012+) — General Topics 15 03-23-2013 01:33 AM
