Old 06-06-2013, 01:16 PM   #15
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
rotiform only makes the SNA in cast, and in 19" sizing. cast wheels cant be changed because the casting itself is permanent/fixed, and they dont seem to want to build a new casting for different sizing/offsets/bolt patterns. to do them in 1 piece forged, custom, figure around $1300 per wheel.
i ran 20/25mm spacers on my factory wheels originally. so 17x7 et28/23. they fit fine at stock height with factory rubber. that is equivelent to 17x8 et41/36 as far as outer fitment goes. obviously you are looking at 18" not 17", but thats not as big of a concern as offset. at stock height on 215 or 225/40/18's, you might be cutting it a bit close. with a slight drop or oem camber crash bolt, i dont see an issue.
I run 18x9 et30 with 245/35/18's all around, 1.75" drop, -2 camber up front, -2.2 rear and its dead on for a reference.
this site is a good reference for offset comparison http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old 06-06-2013, 03:11 PM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
My yoshihara champions were 18x8 +30 front and 18x9 +35 rear, 18x8 +30 would be fine all around.
JoeBoxer is offline   Reply With Quote
Wheel Directory: Enkei PF01 17x8.0 +45 NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-30-2019 09:39 AM
Spacer question for OEM wheels Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-26-2016 06:25 PM
Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Evasive Motorsports Wheels and Tires 31 06-13-2015 09:09 PM
Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric deedz Wheels and Tires 12 05-22-2013 05:18 AM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 12:59 PM
