Old 06-05-2013, 07:07 PM   #1
jacobzking
Drives: White FRS
18x8 +40 WITH 10mm spacer? LFA wheels :)
On ebay you can get LFA replica wheels for only about $650. they're the perfect size and offset... but they are only available in 5x114.3. Project Kics sells a 10mm spacer conversion for $250 but its a 10mm spacer. would the wheels poke out a lot? essentially, this would be like having an 18x8 +50 wheel, right?
added a photoshop of the car with LFA wheels...
jacobzking is offline   Reply With Quote
Old 06-05-2013, 07:12 PM   #2
tisb0b
Drives: Grey GT86 MT
18x8 +40 should be fine adding a 10mm spacer will make it +30 which is probably an unnecessary cost. Stock is +48. Only available in 5x100 isn't a negative given we have a 5x100 bolt pattern.
tisb0b is offline   Reply With Quote
Old 06-05-2013, 07:18 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I think the OP means " but they are only available in 5X114.3"
Old 06-05-2013, 07:29 PM   #4
tisb0b
In which case he'd need a hub conversion kit making it not very viable.
Old 06-05-2013, 08:21 PM   #5
jacobzking
Drives: White FRS
That's what I'm saying. It's a +40 wheel but I would have to use the 10mm spacer adapter. Bad idea?
Old 06-05-2013, 10:05 PM   #6
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
I saw a post for 5x114.3 hubs... U may wanna search for it if u really want 5x114.3 rims
jshadeck is offline   Reply With Quote
Old 06-05-2013, 10:14 PM   #7
jshadeck
jshadeck's Avatar
http://www.ft86club.com/forums/showthread.php?t=32335
Old 06-06-2013, 01:33 AM   #8
jacobzking
Drives: White FRS
i see that megan sells the 5x114.3 conversion. i'm a megan distributor so that would be the way to go BUT... if I just went with the cheap spacer converters... what would that look like? i can never figure out the whole offset calculation thing. wheel is +40 spacer is 10mm so...? is that equivalent to a +30 wheel or +50 wheel? in either case, how would it look?
Old 06-06-2013, 01:55 AM   #9
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
You could make 18x8 +30 work if you really gotta have these wheels.
Old 06-06-2013, 03:03 AM   #10
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
sounds like alot of work for replica.
If you had the real deal yeah sure go for it but not for replica... thats my honest opionon.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 06-06-2013, 03:32 AM   #11
jacobzking
Drives: White FRS
Anyone have any 18x8 +30 wheels on FRS? I'm trying to pick out wheels with my wife and she hates everything I've shown her. Everything looks "too ricey" to her. She suggested stock Lexus/Toyota wheels. That's where I came up with the idea for LFA wheels.
Old 06-06-2013, 03:39 AM   #12
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I have some 18x7.5 +48 volk se37ks and used some H&R spacers to make them all flush - 20mm in front and 30mm in the rear. So in doing so I basically have 18x7.5 +28 in the front and 18x7.5 +18 in the rear.
Funny I wasn't into flushness prior to my FRS, but now that I have it perfectly flush (with help from spacers) I can can say having it flush looks way better than having it sucked in like stock.
mit_peid is offline   Reply With Quote
Old 06-06-2013, 03:55 AM   #13
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
I have 17x8.5+32
Rears fit and are perfect.
Fronts poke a smidge.
So these will be fine
Nafe is offline   Reply With Quote
Old 06-06-2013, 07:45 AM   #14
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
contact rotiform and have them make a set of SNA in 5x100... very similar design to the LFA wheels:
as far as stock wheels go, you don't have much from Toyota/Lexus... I think the only options are from the Corolla, Matrix and tC. I don't think Lexus has anything wth a 5x100 bolt pattern.
Subaru wheels however will mostly fit. Outside of the STI and the Tribeca I think most of their wheels are 5x100.
dori. is offline   Reply With Quote
Wheel Directory: Enkei PF01 17x8.0 +45 NickFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-30-2019 09:39 AM
Spacer question for OEM wheels Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-26-2016 06:25 PM
Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Evasive Motorsports Wheels and Tires 31 06-13-2015 09:09 PM
Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric deedz Wheels and Tires 12 05-22-2013 05:18 AM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 12:59 PM
