#15 | |
Drives: 2013 Asphalt FR-S
Nothing wrong with extra protection, but honestly, I can't think of a failure mode that the IAT would catch that a Window based flow failsafe would not.... If you get a clogged nozzle or line, low flow trips, if you get a line failure high flow trips.
~Namaste~ |
#16 | |
Drives: 2013 Black FR-S
As for a failure mode that the IAT would catch.... like I said it is a failsafe for a failsafe. Ie: a. flow sensor malfunction/damage b. failsafe software malfunction c. electrical malfunction (bad/loose wiring connections) d. Safe Injection boost solenoid malfunction (doesn't send boost to bottom nipple) e. hose to bottom nipple rips, melts, slips off Redundancies are a good thing when dealing with an expensive complicated system. |
#17 | |
~Namaste~ |
#18 |
The water meth injection is theoretically lowering intake temps by at least 40-50 deg F. The tuner's thought is that if the temps read, for example, 150 F and below then it runs the normal meth tune which has timing advanced. If it reads anything higher than that (like 170 F or 200 F etc) then it will retard timing 5 degrees and add fuel.
To determine these temp windows, we would do a few pulls without meth, then a few pulls with meth. |
#19 |
Looking forward to seeing your progress as I plan to run WMI with the innovate kit as well.
BTW - What meth kit are you using?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| What temperature do you put A/C on? | FRiSson | New England | 23 | 06-13-2016 09:55 AM |
| Exterior temperature | 2thdoc | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-28-2013 05:45 PM |
| Temperature not reading below 0 | BrewCity-FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-22-2013 11:05 AM |
| Seat heater temperature? | milenko11 | BRZ First-Gen (2012+) — General Topics | 29 | 09-20-2012 02:19 PM |
| Engine temperature | Skye | Issues | Warranty | Recalls / TSB | 5 | 08-09-2012 11:33 PM |
