Old 06-19-2013, 01:59 AM   #1
sw20kosh
Drives: 2013 Black FR-S
Intake Air Temperature
I tried doing a search but couldn't find an answer. Does anyone know which (if any) turbo/supercharger kits use a new air intake temperature sensor in order to read the air post turbo/supercharger instead of at the MAF (pre-turbo)?
Or do all the kits just relocate the MAF/IAT unit to post intercooler (down stream of intercooler)
Old 06-19-2013, 02:14 AM   #2
jamesm
on my kit they did a blow-through maf. the intake temps were around 105deg with 95deg ambient during test runs.
Old 06-19-2013, 09:05 AM   #3
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I don't know of any that use a seperate IAT sensor yet. However I bet once we get full speed density tuning, you will see people making the switch and ditching the MAF altogether. I will be doing this for sure.
No Limit Motorsport is offline   Reply With Quote
Old 06-19-2013, 09:14 AM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Off the top of my head, FA20club moves the MAF to right before throttle, post turbo, post BOV and post IC. I would have liked that too on my kit.
Old 06-19-2013, 10:50 AM   #5
Foobar
SLO NO MO
Foobar's Avatar
The Vortech is post-charger.
Old 06-19-2013, 11:12 AM   #6
OrbitalEllipses
Drives: Attitude
Haven't seen any kits that include a NEW IAT. Having two is valuable information!
Old 06-19-2013, 12:39 PM   #7
sw20kosh
Thanks for the replies. It is as I had expected. Kits either relocate the whole MAF or they just leave it pre-turbo.
The reason my application needs a new standalone IAT is because I want to set up a 2nd failsafe for my water/meth injection. It would be a failsafe incorporated in the tune. To do this I would need the IAT in the area post twinscrew blower. When that IAT sees cool temps it means the meth is injecting. If it sees 200 C temps then the meth is not inj properly. In the later case timing would be pulled and fuel added.
Just need to find an IAT that can work with the stock wiring(splicing in) and ecu. Please let me know if you come across anything or have any ideas.
Thanks.
Old 06-19-2013, 01:15 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
So does the Full Blown kit. You get pre throttle body IAT that way.
Old 06-19-2013, 01:19 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thanks.
So you are looking to drill and tap one of the intake manifold runners to mount this temp sensor? The GM IAT sensor shoukd work for that and is popular in standalone ecu uses. As to wiring it into the OEM ECU good luck.
Old 06-19-2013, 01:43 PM   #10
mad_sb
Drives: 2013 Asphalt FR-S
Thanks.
Have you looked at the aquamist products? they have flow based failsafe that will do the same thing.. I think a few other companies also use a flow based failsafe (triggers on both low and high flow with adjustable window)...
Old 06-19-2013, 01:45 PM   #11
OrbitalEllipses
Drives: Attitude
I was going to suggest a GM IAT, but I had only seen it used with Hydra, AEM, etc. so I just didn't say anything. It's POSSIBLE that with Ecutek you could cannibalize some function that you don't need, similar to how Ecutek uses the EVAP charcoal solenoid for boost.
Old 06-19-2013, 01:58 PM   #12
No Limit Motorsport
Thanks.
The GM IAT sensor works good with the stock ECU 02-13 WRX/STI with Cobb or Open Source speed density software. I wouldn't be surprised if it works with our cars as well.
Old 06-19-2013, 02:38 PM   #13
sw20kosh
Already installed and working great! That is why I said "a 2nd failsafe". I'd like to have a back up in case something goes wrong with that one.
A failsafe for a failsafe. Never can be too careful when it comes to blowing an engine...
Old 06-19-2013, 02:51 PM   #14
OrbitalEllipses
Drives: Attitude
Use protection...
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 09:55 AM
Exterior temperature 2thdoc Scion FR-S / Toyota 86 GT86 General Forum 15 04-28-2013 05:45 PM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 11:05 AM
Seat heater temperature? milenko11 BRZ First-Gen (2012+) — General Topics 29 09-20-2012 02:19 PM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 11:33 PM
