#15 |
Drives: none =[[
its not auto diagnostic forum here, no one will help much here. only will tell you go to dealership
check voltage when you turn key on crank position maybe starter fuse blow? for some strange reason check all the fuse, worth a shot |
#16 |
All sorts will try to help. Very few will succeed. It is the same as saying "I have this noise what is it". A thousand people can throw ideas at it but without being able to see and touch it there is little value in them.
#17 |
Drives: 2015 FRS
It may be a long shot... but I do very much appreciate the suggestions. Next I will try fuses. Any particulars to check? Not sure which fuse is starter... I guess I can just pullemall. But there are quite a few.
2015 FRS Ultramarine.
#18 | |
Maybe I don't understand what you're saying, but based on what he wrote, I can't see how getting a jump would help. Checking the fuse makes the most sense. |
#19 |
@SkiRideDrive I'll help you out. Definitely a fuse... I'll dig up the proper slot and post a pic shortly. Pretty sure the one you're looking for is going to be a 7.5a and should be spares in the box under the hood.
#20 | |
Drives: 2015 FRS
#21 | |
Fuse 1 in engine compartment.
#22 |
Drives: FBRZS
#23 |
Drives: 2015 FRS
This diagram looks quite a bit different than what I am staring at in my 2015 frs.
#24 |
These kinds of stupid posts aren't funny anymore nor are they conducive to helping anyone in anyway. Way to make everyone on the forum look bad
#25 |
Drives: 2015 FRS
Beastronix has been in contact with me via email. Very helpful. Have gone through a few fuses and haven't quite found the problem yet. Will continue to diagnose tomorrow. Thanks for the help guys.
#26 |
I have never looked at it against the real thing it was given a long time ago as the proper one. So I can't vouch that it is.
#27 | |
Get together smart people, like we have on this forum, and the sky's the limit as to the help they can provide. |
#28 | |
Generally if the alarm/security light is flashing the alarm/security is still active and the car will not start We dont have the alarm function in my country just the immobilizer. if all the dash lights illuminate and headlights work ect but car wont crank and imobilier/security light still flashing then i would concentrate on some issue with security system check the imobiliser/alarm fuses plugs/connections to alarm/imobiliser ect. also measure the battery volts under load even a dead battery can measure ok unloaded. as well as checking fuses check the big fusible links under the bonnet. |
| Pushed start.. didnt start | im_topher | Engine, Exhaust, Transmission | 86 | 11-29-2015 10:57 AM |
| Where did you start with your FR-S/BRZ | jeepmor | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-10-2014 02:39 AM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 07:06 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 03:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
