#29 | |
![]() Apparently, the FR-S has an "active" release bearing (TOB). It runs anytime the engine is running. However, it just "works" when the clutch is pushed in. A very slight pressure from the slave cylinder keeps it in contact with the fingers of the pressure plate at all times. So, if is really bad, it can howl without the clutch being pushed in. humfrz |
#30 |
not playing cards
For the record, I didn't assign a specific name to the system. I don't really know if it's called anything special. It's a run-of-the-mill, self-adjusting hydraulic clutch. And yes, the TOB is rotating 100% of the time. ...unless it's starting to seize. Then it screeches.
#31 | |
That's more descriptive ...... ![]() humfrz |
#32 |
not playing cards
I think it's just a cable-versus-hydraulic thing, no? I'm with you. I just wonder if there are any functional variants.
#33 |
#34 |
Yes, i did some more reading on that topic gentlemen. You learning something new everyday!
#35 | |
![]() ......except fer ol @Tcoat ....... and he thinks he knows it all ....... ![]() ![]() ![]() ![]() ![]() ![]() ![]() humfrz |
#36 | |
#37 |
hmmmm.........how does one know what they don't know"..... if they don't know, if what they don't know, even exists .......
![]() Next we shall discuss the tree falling in the forest ......... ![]() Meanwhile, if I can get mrs humfrz showered up and dressed, we are going to take a ride up into the hills of the coal country. Yep, back in the day, they mined coal not to far from here ...... ![]() humfrz |
#38 |
not playing cards
#39 |
not playing cards
Fuck off, Rummy.
| Tags |
| differential, loose bolt, transmission |
| Horrible bucking and shutter after clutch install | Scikotic | Engine, Exhaust, Transmission | 32 | 07-12-2016 09:10 PM |
| Runduce 6-Speed Transmission Gear - 500hp | botbs | Engine, Exhaust, Transmission | 10 | 11-22-2015 03:59 PM |
| is it ok to slip my clutch often in 2nd gear when my rpm is below 2k? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 06-17-2015 07:12 PM |
| What's this clunk sound coming from 2nd gear after letting go of the clutch ? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 04-30-2015 03:14 AM |
| Cold morning and horrible grinding/screeching sound | Books | Issues | Warranty | Recalls / TSB | 1 | 11-14-2012 03:18 PM |
