Old 05-05-2022, 02:15 AM   #29
Ultramaroon
not playing cards
Ultramaroon's Avatar
This is one of the most interesting solves in a while. Just last weekend, my wife re-told the story of how her dad would call her out for resting her foot on the clutch.
10/10 thread.
Old 05-05-2022, 03:14 AM   #30
tomm.brz
Drives: brz 2017 hksv2
good steve finds always a way, he s the best
i got confused by the fact his. log didn t have all the normal values logged by default by ecutek, but now we know it s kind of easier to spot from the afr target he gets too
steve we love. you
Old 05-05-2022, 03:36 AM   #31
Ultramaroon
not playing cards
steve we love. you
+1 Steve. Even took the time to mostly spell-check. Maybe someone hacked his account.
I was thinking that it would be interesting to log everything while playing with the switch, but it already makes perfect sense in hindsight.
Old 05-05-2022, 03:43 AM   #32
tomm.brz
+1 Steve. Even took the time to spell-check. Maybe someone hacked his account.
yes when you log clutch switch (it s not default value) it shows immediately as clutch switch value would jump to 1 when it starts the bog
Old 05-05-2022, 12:14 PM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
10/10 thread.
Yeah, that was a good one
Old 06-05-2022, 10:57 PM   #34
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Finally putting this one to bed. PTuning sent me an update which turned off ffs and P0420. I can drive my car with my foot touching (but not riding, since I don't want to piss off @ultramoon's father in law)) the clutch before I shift. What a joy.
Old 06-07-2022, 07:50 AM   #35
steve99
Originally Posted by blsfrs View Post
I drove home this afternoon and was able to do a couple of pulls and VOILA', no bog. I experimented with the cruise control. The slightest touch on the clutch pedal turned it off. As per @steve99, I will have the tuner disable FFS since these transmissions would probably go bang after 2-3 FFS's. Thanks again.
the standard ecutek FFS setup is quite harsh as it actually hold the rpm 200 rpm above the rpm clutch was pressed. for smooth shifts you want to have the rpm hold between 200 less to 1200 rpm less than when clutch pressed ( depending on the rpm of shift, i calculated this of the average gear ratio change and this produces very smooth shifts like an auto actually smoother than you can do yourself.
Old 06-07-2022, 09:29 AM   #36
blsfrs
blsfrs's Avatar
On the dyno, it actually looks fairly smooth.
Old 06-07-2022, 12:28 PM   #37
Ultramaroon
not playing cards
That's terrible! Why even bother having the feature?
Old 06-07-2022, 07:23 PM   #38
tomm.brz
that' s terrible for the clutch and transmission. but allows for the quickest shift, as it "pushes" the car forward as you change gears
Old 06-07-2022, 09:29 PM   #39
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have had the same problem with my car. Sudden cut of between 5 and 7k rpm about 5 times now. I went out driving today and tested the cruise. It took an unbelievably baby push on the clutch to turn it off. I usually run my car with the tune that includes racerom features. I like the auto blip.
So I tried to replicate the cutoff. Couldn't do it. Now going to run the tune without racerom and see if it happens again.
car bogging when coming to stop Qball1754 Engine, Exhaust, Transmission 10 06-06-2019 12:39 PM
Engine bogging down FRiSson Issues | Warranty | Recalls / TSB 6 08-14-2015 09:07 PM
Vortech FR-S Bogging RPM AND STALL ScionFR-S Forced Induction 9 07-24-2015 06:52 PM
random bogging/stalling - no cel though edsbreezy Issues | Warranty | Recalls / TSB 5 04-22-2014 10:58 PM
Transmission Dry Sound & Bogging jjkerr626 Engine, Exhaust, Transmission 3 06-11-2013 01:10 AM
