Old 06-09-2013, 12:55 AM   #1
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Transmission Dry Sound & Bogging
Hi everyone, I am not too technically inclined so I will explain what I think is happening and maybe you can help me decide if this is normal for this car or I need to take it in for service.
When I am starting off and letting the clutch out the transmission makes a sort of bogging sound at low RPM's. once the tach is over 2k it generally goes away. It reminds me of that spud you get when the car doesn't have enough power. My buddy @DJLtoronto said it reminds him of a dry clunking sound.
It also does this mildly into second gear but not as noticeable as first.
Would It help to change my tranny oil? Or do I need service work. Thank you.
Jay
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 06-09-2013, 01:18 AM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
It can't hurt to change your transmission fluid with some higher quality stuff. It really just sounds like you need to give it a little more gas and let the clutch out nice and slowly while slowly applying a little bit on the gas pedal. They will bog down if you are dumping the clutch or not giving it enough gas.
Sent from my SGH-T989 using Tapatalk 2
Old 06-09-2013, 01:53 AM   #3
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I just put in Motul Gear 300 for my 30K service and now my downshifts are so buttery! I would say if you think something has changed or their might be an issue it doesn't hurt to change the fluid.
Old 06-11-2013, 01:10 AM   #4
jjkerr626
jjkerr626's Avatar
Thanks guys!
Engine bogging down FRiSson Issues | Warranty | Recalls / TSB 6 08-14-2015 09:07 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Bogging Question??!! Help needed... ScionFrsFan Engine, Exhaust, Transmission 36 02-05-2013 07:44 PM
Transmission Sound... chipz91 Scion FR-S / Toyota 86 GT86 General Forum 13 08-21-2012 02:30 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
