View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler
WITH Oil Cooler Spirited Street Driving < 195 F 12 8.28%
WITH Oil Cooler Spirited Street Driving 195-215 F 9 6.21%
WITH Oil Cooler Spirited Street Driving 215-230 F 11 7.59%
WITH Oil Cooler Spirited Street Driving 230-245 F 3 2.07%
WITH Oil Cooler Spirited Street Driving 245-260 F 0 0%
WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) 0 0%
With Oil Cooler Tracked 195-215 F 5 3.45%
With Oil Cooler Tracked 215-230 F 4 2.76%
With Oil Cooler Tracked 230-245 F 7 4.83%
With Oil Cooler Tracked 245-260 F 6 4.14%
With Oil Cooler Tracked 260-280 F 2 1.38%
With Oil Cooler Tracked 280 + F 0 0%
W/O Oil Cooler Spirited Street Driving < 195 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 195-215 F 6 4.14%
W/O Oil Cooler Spirited Street Driving 215-230 F 30 20.69%
W/O Oil Cooler Spirited Street Driving 230-245 F 16 11.03%
W/O Oil Cooler Spirited Street Driving 245-260 F 11 7.59%
W/O Oil Cooler Spirited Street Driving 260-280 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 280 + F 0 0%
W/O Oil Cooler Tracked 215-230 F 0 0%
W/O Oil Cooler Tracked 230-245 F 2 1.38%
W/O Oil Cooler Tracked 245-260 F 8 5.52%
W/O Oil Cooler Tracked 260-280 F 24 16.55%
W/O Oil Cooler Tracked 280-290 F 5 3.45%
W/O Oil Cooler Tracked 290 + F 4 2.76%
Multiple Choice Poll. Voters: 145. You may not vote on this poll
Old 02-28-2013, 03:32 AM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Sportsguy83 View Post
290 is WOW...
Your numbers are prior to oil cooler or after?
After the cooler.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-28-2013, 04:58 AM   #30
ft_sjo
Drives: GT86
If that's the case,
#1) He has not been reading the forum in which vendors are saying an oil cooler is ABSOLUTELY necessary even for a DD (thus why independently test it myself on harsher conditions).
#2) He didn't read my first post to see what type of tests I did.
I'll spell it out for you to save any further assumptions.
Driving around with no load at 6k rpm isn't going to tell you much about oil system capacity, other than what it does in those conditions, which is of not much use to anyone.
Your test of driving WOT up to 100mph or whatever will most likely put more heat into the engine than your extended part throttle testings.
If you want to test the system properly, then you need to sit at WOT for extended periods of time.
I think it's great that people want to do tests and show the results to the community, but please try and ensure they're actually worthwhile or it just ends up misleading people.
Old 02-28-2013, 05:02 AM   #31
robispec
Drives: Black frs project
290 is WOW...
off the obd2 sensor in the block right under the oil filter (3/8 pipe tap 2 wire sensor is pressure next to it is a 1/8th one wire temp sensor)
no oil cooler went back to stock to see how bad it was. day was 75 degrees in the PM and the car SLOWED DOWN after it reached a certain temp...
in the morning the car was doing 10 mph faster exiting turn 2
PS At the ACS "ROVAL" in Fontana CA you are at full throttle for 80% of your lap time and every lap you have a 40 second burst of WOT in the top three gears this was when I was seeing peak oil temps... The Z was the same way as the oil is used for the cam timing changes and this compresses the oil heating it up.
robispec is offline   Reply With Quote
Old 02-28-2013, 05:02 AM   #32
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Can you explain to me how going between 5-7K back and forth is not loading the engine? I didn't keep the throttle constant at 6K and called it a day (kind of hard to do BTW for 8 minutes). I punched it back and forth to keep it at those RPM and of course, I wanted the engine to be loaded. If you read my first post, I said "this is not the final testing nor the definitive testing, just a start". I also said "the real test is at the track", like Robispec did.... Moreso, if you look at my recommendations, a DD should not need an oil cooler but a track car I recommend an oil cooler. Do you think those recommendations are not accurate?
If my WOT to 100 mph put more heat then the other test, why did the oil/coolant temperature stayed in check, but for the "track" test the oil temp rose like a b*tch?
Old 02-28-2013, 05:04 AM   #33
Sportsguy83
Drives: Limited BRZ
Originally Posted by robispec View Post
off the obd2 sensor in the block right under the oil filter (3/8 pipe tap 2 wirw sensor is pressure next to it is a 1/8th one wire temp sensor)
Rob, do you remember ambient temperature those times (at least estimate?)
Old 02-28-2013, 05:14 AM   #34
ft_sjo
Drives: GT86
It's pretty obvious that a daily driver doesn't need an oil cooler otherwise the manufacturer would have fitted one. I'm fairly sure they would have spent considerable time driving the vehicle in all conditions in all scenarios all round the world to come to that conclusion.
Surely the question is more over do people need an oil cooler on track? If so then people who have driven their cars on track have already posted up numbers they've seen, however i've only seen one person post up figures that they've actually seen an oil pressure drop. Until more than one person does that then no, in my opinion, I don't think there is a need for an oil cooler.
And for the record, I read your first post quite clearly. It does not state you alternated from 5-7k, it said you kept it over 6k, it didn't mention at what load level. To be technical about it, then yes any load on the engine including a static test is 'load', but it's not the type of load that's going to cause you oil temperature problems.
Bear in mind how inefficient IC engines are. There's a lot of heat to be gotten rid of, and there's a huge difference between 30-40hp on a light static cruise than there is at 150hp+ consistently.
Don't see this as an attack. It's critique and it's healthy to entertain it.
Old 02-28-2013, 05:14 AM   #35
robispec
yes 76 degrees
Old 02-28-2013, 05:24 AM   #36
Sportsguy83
Drives: Limited BRZ
Thanks, I am willing to be schooled. I agree the first post wasn't that specific. I respect your opinion and appreciate your input and YES, definitely this minimal test should NOT tell anyone "go get an oil cooler".
I actually am in your camp. I need more data and info before buying one. My intent on doing this was specifically because there are vendors that say an Oil cooler is needed by everyone. IMHO before logging numbers, I didn't think it was necessary for a DD who drove spirited, liked to floor it often, etc. But, since I am not the oracle I wanted to see for myself what kind of numbers we were dealing with. I hope this post is just a first step to much more data and way better/more accurate tests to determine if a track car really needs it, including FI cars. :happy0180:
Old 02-28-2013, 05:36 AM   #37
ft_sjo
Drives: GT86
As a wise engineer once told me, "Test, don't guess!"..
But he also told me "Never let the truth get in the way of a good story!".... which could apply to some vendors on here..
My day job is to provide solutions to a problem. Until I see a problem I won't try to solve it. I think that's where we are with the oil temperature thing.
The simple solution is this. Fit an oil cooler and blank off air flow to it until you need it, e.g. a track day.
Old 02-28-2013, 05:36 AM   #38
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Track day with me being no super star (just a beginner) with ambient temperature around 78F (26C) my oil temp topped out at 255F (124C).
A more spirited and accomplished track racer here in NZ topped their oil temp out at 284F (140C) in similar conditions - they're fitting an oil cooler!
One of our club has installed the HKS oil cooler and on track it now tops out now at 212F (100C).
I am likely to track about 5 or 6 times per year and am undecided on the oil cooler at this stage although I like the look of the Perrin one.
Hope this temp info helps.
nzer is offline   Reply With Quote
Old 02-28-2013, 05:39 AM   #39
Sportsguy83
Drives: Limited BRZ
It helps a LOT thanks!
Old 02-28-2013, 05:53 AM   #40
polancd
Drives: a few
It was 72 F. I updated the first post.
I definitely will if we get a hot day soon.
Agree with Dave and you.
When I said I would see higher oil temps, I meant doing the same test I did today but ambient temp. at 90+.
When I install the temp gauge to the oil galley I will do comparisons to the OEM sensor.
Thanks for sharing your numbers!
Sent from my HTC One X using Tapatalk 2
Sorry, I meant what was the baseline oil temp before you started driving hard? Also i am guessing you are using 0w20?
polancd is offline   Reply With Quote
Old 02-28-2013, 05:56 AM   #41
Sportsguy83
Drives: Limited BRZ
Oil was at 190 F when I started. Yes, 0w20.
Old 02-28-2013, 08:40 AM   #42
keelerad
keelerad's Avatar
Drives: Silver Manual Toyota GT86
Did a training/trackday here in the UK on Feb 14th. Ambient was about 3 C (37 F) had to wait for the snow to melt a bit before we could start
Car is standard apart from a K&N air filter, with moderate track use (as fast as I as a beginner wanted to go) it peaked at 120 C (250 F)
For pictures, torque screenshots, videos etc see http://www.gt86ownersclub.co.uk/foru...topic2412.html
Bed and Breakfast car park the night before
Screenshot from Torque, peak Oil Temp 120 C
Normal daily driving sees it get up to between 90 - 100 C, a bit of a thrash on the road takes it up to 108-110 C
Alec
keelerad is offline   Reply With Quote
oil cooler
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 09:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 05:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 06:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-22-2013 12:36 AM
Oil Cooler Location? Captain Snooze Engine, Exhaust, Transmission 5 11-26-2012 06:02 PM
