Old 05-02-2016, 04:36 AM   #29
Blokatos
Drives: MX5 Miata Mk2.5 1.6
Originally Posted by SiSGT86 View Post
^ what's up with you FI guys hijacking every thread whether it's about tuning an NA or taking out weight of a car. Your ideas a redundant, uninspiring and un-original. Not to mention incredibly annoying.
Blokatos is offline   Reply With Quote
Old 05-02-2016, 05:03 AM   #30
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
From an engineering perspective; No.
Turbos are used for much much higher volumetric effiency that yields a higher output force. NA engines can only get so much power down using 14.7 psi before displacement needs to be bumped up.
Old 05-02-2016, 09:26 AM   #31
FT86RGV
http://shraderperformance.com/shop/p...r-seat-delete/
FT86RGV is offline   Reply With Quote
Old 05-02-2016, 12:07 PM   #32
BRZHarley
Drives: 69 Firebird, 2015 BRZ
The Shrader kit linked above will allow you to fold down the rear partition... I have kit in my BRZ and recommend it... It won't save you the max you could but it will remove a total net of 20lbs.
Ed
BRZHarley is offline   Reply With Quote
Old 05-02-2016, 02:58 PM   #33
Norville Rogers
Drives: Subaru BRZ
Originally Posted by ender2664 View Post
On alot of sights i see carbon fiber trunks and hoods claiming 70% weight reduction.
That's from your wallet
Norville Rogers is offline   Reply With Quote
Old 05-02-2016, 03:21 PM   #34
Cole
Not a troll
Cole's Avatar
Wow, epic resurrection, with absolutely nothing added.
11/10
Old 05-02-2016, 03:33 PM   #35
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by Blokatos View Post
Why would you necro this thread to post this?
jawn is offline   Reply With Quote
Old 05-03-2016, 01:41 AM   #36
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Originally Posted by Sciby View Post
You'd have to get a completely sealed battery - most have vents, hence them being in the engine bay. Some are mounted in the boot (ala R33/34 Skylines) but that's beacuse the rear seat doesn't fold down, etc.
LOL I once had an 83 Alfa Romeo Quadrifoglio Hatch where the battery was in the back. Took a turn too hard once and the battery came loose of it's bracket and leaked all over the boot.
80's Italian engineering and safety didn't really go hand in hand.
Wise is offline   Reply With Quote
Old 05-03-2016, 02:37 AM   #37
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by boredom.is.me View Post
5- You'll never have a flat as long as you have your spare. As soon as you take the spare out, you'll end up with a flat.
AAA subscription> spare
Old 08-13-2017, 02:37 PM   #38
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Tore everything out of the back. Added in a small harborfrieght pump with tire plugs and can of fix-o-flat. Added about 4lbs back in but lost so much more without the tools and spare.
SuperTom is offline   Reply With Quote
Weight..... icemang17 Tracking / Autocross / HPDE / Drifting 2 07-02-2012 07:24 PM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 03:55 PM
Actual Weight For FRS??? DanPO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-22-2012 06:07 PM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 03:04 AM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 11:43 PM
