Drives: 2013 Scion FRS
Shaving weight
On alot of sights i see carbon fiber trunks and hoods claiming 70% weight reduction. However I don't know the stock weight of those parts, does anyone know how much weight I will lose by doing a hood and trunk.
Also I really don't want carbon fiber showing on my exterior. Does anyone know any alternatives? Such as a company that sell fiber glass parts? Has a rear seat delete kit come out for the car that isn't made of carbon fiber? I want to get rid of that weight, but I am not going to spend 1750 to do it. |
Search tool should reveal where all the stock part weights are listed. I highly doubt even a dry carbon hood would weigh 70% less than aluminum. Trunklid maybe.
You can paint carbon fiber body color. Usually best to order the parts without a clear coat so they can be painted. Rear seat delete kit you can make yourself out of Coroplast (corrugated plastic) for next to nothing. Big sheets of it can be bought in just about any color.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
Drives: 2013 FR-S whiteout
You might save 2 lbs on the hood and 2lbs on the rear seats and spend $2k.
I'll only charge you $100 to remove the spare tire. Much better bang for your buck. |
Custom User Title
Drives: Asphalt FR-S MT
Give me $500, then lose weight.
Drives: 04 Subaru WRX
Drives: Hot Lava 2013 Scion Frs
Carbon Fiber hood/trunk for this car is basically throwing your money in the garbage. The stock hood and trunk are already extremely light and for 2-3k you might drop 5 lbs between the two. Best place to start with the weight saving is the trunk junk(30ish lbs) and that is free. Then in the front, where it would be more beneficial to drop weight, a lightweight battery is a great way to start. A good reliable one can be expensive, but your looking at 20 lbs right there. Then get in your drivers seat and hold the windshield washer fluid button down until its all gone, theres another free 8 lbs. So yea moral of the story, CF is a waste of cash.
Drives: BRZ Limited arrived on 9/1/2012
Just in case you forget about this: take out the owner's manual from the grove box, a few pounds. Front and rear rug set: another pound. Fill up has tank only half full: some weight there.
For the price of CF hood trunk, I will go for light weight rims. |
.....Eat fewer cheeseburgers.
The first mods to my car I have decided are going to be the following-
1-Lose a shit load of weight (which will save me money for future mods ![]() 2-KnN filter and light weight crank pully 3-silicone hose 4-Light weight battery 5- take out the stuff in the trunk 6- lighten the fluid load 7- find a rear seat delete kit (I am to lazy/busy to make my own) From there I am going to figure out what I can do on the exhaust side while keeping the car quite and get a tune to match it up. |
#10 |
Custom User Title
5- You'll never have a flat as long as you have your spare. As soon as you take the spare out, you'll end up with a flat.
#11 |
Worry first about losing un-sprung weight. That is where you'll notice the greatest benefit. The stock wheels weigh a lot; you can see a real benefit in switching to lightweight wheels and tires. Then for the same money as you spend on a hood and trunk, you could get an AP Racing or Wilwood brake kit which would not only shave weight but improve braking performance. Coil-overs usually weigh the same or more than stock strut/spring combos, but offer you more adjustability. I'm not sure if anyone makes these, but a hollow sway bar is going to weigh less than a solid bar.
A lightweight battery is inexpensive and saves significant weight. The stock airbox can be replaced with something aftermarket and save a couple pounds. you can pull the "subaru - toyota" cap off the intake plenum and shave a couple ounces there, too. Lightweight pulleys reduce drag and save weight. A lightweight flywheel and carbon fiber driveshaft saves weight and improves response. A full aftermarket exhaust system saves weight and adds power. When you've exhausted every other option, then it's time to think about replacing panels with carbon fiber. That is where you gain the least weight reduction for your money. There's an old saying: worry about the ounces, and the pounds will come.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. Last edited by Turbowned; 03-18-2013 at 11:40 AM. |
#12 |
Drives: White 2013 BRZ Limited 6MT
A battery relocation kit will transfer more weight to your trunk area, and lighten the front. It makes a huge difference in handling and acceleration. That may be your best bet at this point
#13 |
Thank you for the information and ideas.
I popped my hood for the first time the other day and that thing is crazy light. I completely realize now why no replacement hood is going to save much weight, especially for the money. |
#14 | |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Unsprung weight > dead weight. Reduce it as much as you can. If your serious about weight loss, 16x7's or 16x8's would be the go(provided you don't want BBK). Forged monoblock rims ftw. Elaborating further.. For anyone doubting the potential of weight reduction, try this(4 small minor mods that will only take 30mins tops) 1) Remove spare wheel and any other stuff in the boot compartment. 2) Hold down the washer fluid button till the reservoir is empty. 3) Remove your passenger seat(only as a trial, not permanent) 4) 1/3 Fuel in the gas tank. Easy 50-55kg(100-110lbs) lost just by those 3 quick modifications. See if you notice the difference then.. |
| Weight..... | icemang17 | Tracking / Autocross / HPDE / Drifting | 2 | 07-02-2012 07:24 PM |
| Non USDM BRZ oil weight | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-21-2012 03:55 PM |
| Actual Weight For FRS??? | DanPO | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-22-2012 06:07 PM |
| Official JDM BRZ weight and MPG | ayau | BRZ First-Gen (2012+) — General Topics | 50 | 02-08-2012 03:04 AM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 11:43 PM |
