Old 06-19-2013, 10:45 PM   #29
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Originally Posted by djdnz View Post
At the moment I am, I have RCE Tarmac Zero on the way but the wheels will arrive first. I'll try mounting them on the stock suspension at first until the coils arrive.
Please turn the front to lock, to check if they hit the front struts! I would like to know this! Thanks
hanabie is offline   Reply With Quote
Old 06-21-2013, 12:58 PM   #30
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Kitty approved. They look wide...
If anyone is interested, this is the look of 245/35/18 Continental ExtremeContact DW mounted to 9" wheels.
Now show us with them on damnit! LOL
What coil's you got? I want to get BC racing cause i'm on a budget...but still to broke for those atm. gotta ride stock for another 2 months (n)
joergasm is offline   Reply With Quote
Old 06-21-2013, 01:23 PM   #31
hanabie
hanabie's Avatar
I really can't say much about BC coils, but you should not go for cheap coils.
In terms of coils, you are looking for manufacturers that produce superb quality shocks not the springs. So, it is really you get what you pay for.
I'd get Tarmac 0 if I were you. They are made by KW.
If you lower your car more than 1 inch, you are really looking for LCA investment. I hope I'm wrong, but I was informed that.
I went with swift springs route. I can live with 1" drop.
When my oem struts blow, I'll be looking to invest something like KW V3. Then, I will sell my swift with minimal lost.
Old 06-26-2013, 01:30 PM   #32
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
looking forward to seeing more pics; especially with a drop. these are on my list.
smbstyle is offline   Reply With Quote
Old 06-28-2013, 03:44 PM   #33
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
So did these ever fit, or what?
The Racers Line is offline   Reply With Quote
Old 06-29-2013, 09:07 PM   #34
joergasm
joergasm's Avatar
Where are the mounted pics, we all waiting!!
Old 06-30-2013, 10:24 AM   #35
djdnz
1337
Drives: 2013 BRZ WRB S/C
I test fit one wheel in this thread:
http://www.ft86club.com/forums/showt...hlight=bremmer
My coilovers arrive on Wednesday! Hope I can get them installed before the weekend, and then I'll get some pics. The wheels are totally mexi-flush in the front at stock height. They should tuck nicely with the drop though
djdnz is offline   Reply With Quote
Old 06-30-2013, 12:48 PM   #36
The Racers Line
See, I'm sure they will fit with coilovers. I was just hoping they would fit with the stock struts and lowering springs because I don't really want to buy coilovers.
Old 07-01-2013, 01:28 AM   #37
djdnz
1337
Given how tight it looked at stock height, they likely be extremely close or interfering with lowering springs unless you remove some of the natural camber or add spacers. I'm not too sure what others experience has been like with lowering springs on aggressive fitments. I'm assuming you generally lose some space at the tire. If you put a stretched tire you might fit a bit better, but personally its not my thing.
They definitely fit at stock height as shown in my other post. You might be able to sqeeze a slightly wider tire on than I have at stock height. But Mexiflush already!
Old 07-09-2013, 02:11 PM   #38
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 09-18-2013, 02:18 AM   #39
Dan@AWD
Drives: 2013 Argento FR-S
Have you tried installing the 18x9 w/ 255/35 in the front to see how it fit?
Dan@AWD is offline   Reply With Quote
Old 09-26-2013, 03:31 PM   #40
joergasm
joergasm's Avatar
No I haven't but there is another person that is using 18x9 but not sure what size tires. You can check the wheel directory under bremmer kraft should be the other guy there.
Old 09-26-2013, 03:32 PM   #41
joergasm
joergasm's Avatar
Hope these shot's help for anyone wondering how much clearance you may have with the 18x8 in the front.
Old 09-26-2013, 05:03 PM   #42
hanabie
hanabie's Avatar
18x9 only gives 3mm clearance left. I believe the tire size was 235
Wheel Directory: 3SDM 0.01 18x8.5 +35/18x9.5 +35 Adrenaline Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-14-2016 02:24 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 09:10 AM
Wheel Directory: Bremmer Kraft BR10 18x9.0 +42 djdnz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 11-29-2013 03:32 PM
Wheel Directory: XXR 531 18x8.5 +35 / 18x9.5 +35 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-07-2013 01:43 PM
Bremmer Kraft grgonium Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-14-2012 08:30 PM
