Old 06-21-2013, 12:52 AM   #1
djdnz
1337
Drives: 2013 BRZ WRB S/C
Thumbs up Wheel Directory: Bremmer Kraft BR10 18x9.0 +42
Here's my BRZ, it has Bremmer Kraft BR10 18x9+42 wheels. Tires are Continental ExtremeContactDW 245/35/18, coilover suspension 1.25" with RCE Tarmac T-Zero coilovers
10/15 Two new pics
09/04 Update
Since someone asked, this is the only other pic I've taken so far
08/19 Update:
Cellphone pics:
06/20/2013
Original Post:
I received my wheels yesterday and only got a chance to quickly test fit one front wheel tonight. I will get some more pics next week. We have already seen it on the rears in another thread, but I will be running a 18x9+42 square.
Specs:
Bremmer Kraft BR10 18x9+42 w/ 245/35/18 Continental DW ExtremeContact
Stock height for now, waiting on Tarmac Zeroes to arrive
I just put the car back on the ground after being jacked up, so it's sitting a little high I think. The car is also on a slanted driveway. It's currently poking about 10mm, I think lowering 1" will make it nice. I'm thinking the rear will need a 5mm spacer to bring it to flush at that height. The tires are a bit more stretched than I would have liked, but I wanted to avoid adding any more unnecessary weight. I think 255's would be a bit nicer on the eyes, and the Continentals don't help much based on their shape.
I have checked for rubbing, it is VERY close to the stock spring perch but it clears by 2-3mm, have tried rotating the wheel left to right, no additional issues. It's a bit too close for my comfort level so I'm not sure if I will mount them permanently until I get the coils on.
Strut Clearance
Top, wheel straight:
Turned Hard Left
Turned Hard Right
djdnz is offline   Reply With Quote
Old 06-21-2013, 01:17 AM   #2
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
You have pics of the whole car with wheels on? Lookin good so far.
sprintertrueno86 is offline   Reply With Quote
Old 06-21-2013, 01:31 AM   #3
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Love the wheels. Waiting for more pics.
Mad_Mike is offline   Reply With Quote
Old 06-22-2013, 02:15 AM   #4
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Many thanks for that front pic.. it helps alot!
Sent from my SGH-T999 using Tapatalk 4 Beta
hanabie is offline   Reply With Quote
Old 06-22-2013, 02:55 PM   #5
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Damnit, that means there's no way these are going to fit with any drop+camber without a spacer
The Racers Line is offline   Reply With Quote
Old 06-22-2013, 04:30 PM   #6
hanabie
hanabie's Avatar
you could only do it 18x8 front.
I thought adding negative chamber would definitely hit the front strut.
Old 07-01-2013, 01:19 PM   #7
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
That's what I was scared of so I did the staggered way, but I also like the staggered look haha. So win-win.
I have them but have not check lmao but the 18x9 at back has the same clearance/distance from the strut right?
joergasm is offline   Reply With Quote
Old 07-01-2013, 01:21 PM   #8
joergasm
joergasm's Avatar
Hope your liking the wheels dude, glad I was able to help you decide on them!
Old 07-01-2013, 01:46 PM   #9
hanabie
hanabie's Avatar
Reason is, the wheels at the back are fixed. They don't make hard corner turns just like your front.
Now, how is the wheels quality so far?
Old 07-02-2013, 09:25 AM   #10
djdnz
1337
Pretty much what I'm thinking. As I said in joergasm's thread, I think you'd have to remove camber if you drop with springs and don't want spacers. You might be able to make it work though... hard to say for sure without trying.
No problem, more to follow - hopefully this week, coilovers should arrive tonight or tomorrow
Yeah the fronts are very close, if you're not going coilovers I think you made the wise choice. The rears should be no issue at all.
Yeah thanks for the pics you posted, I wasn't too sure about them since I haven't read much about the brand, but pretty happy with them (sitting on my garage floor anyway lol)
Old 07-03-2013, 12:13 PM   #11
bjun
bjun's Avatar
Drives: white premium brz M/T
So 18x9 fits the front with 245 tires?
Do you suggest any camber/spacers?
bjun is offline   Reply With Quote
Old 07-03-2013, 05:48 PM   #12
djdnz
1337
Since your signature says you have KW V3's, there is no issue with clearance. Spacers are not required when you have coilovers. Camber is your preference, but there should be lots of room for camber adjustment.
Old 07-04-2013, 11:14 PM   #13
bjun
bjun's Avatar
Ya I got the coils n wheels. Just need tires but every discount tires I go to denies me service bc their computer says 18x9 won't fit the front =/
Old 07-09-2013, 02:14 PM   #14
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Wheel Directory: XXR 530 18x9.75 +20 alexfrspr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 02-09-2017 09:02 AM
Wheel Directory: Bremmer Kraft BR10 18x8.0 +45 / 18x9.0 +42 joergasm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 11-11-2014 10:01 PM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 04:15 AM
Bremmer Kraft grgonium Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-14-2012 08:30 PM
