CANADA Canada
Old 01-03-2014, 12:51 PM   #29
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by Taro View Post
I popped open my hood to check after I saw this topic, and my FRS does NOT have the battery described by the OP. Maybe BRZs and FRSs come with different batteries? I've never had trouble starting, parked inside or out.
Edit: it could be the tranny. OP had a standard, mine is auto.
Auto equipped cars have the proper sized 500 CCA battery. Mine is only 340 CCA which is a joke around here.
Suberman is offline   Reply With Quote
Old 01-21-2014, 09:35 PM   #30
Hardy
Hardy's Avatar
Drives: '14 BRZ Sport Tech, Lightning Red
I'll have to pop the hood on mine tomorrow and check. Was in Thunder Bay over Christmas and it easily fired every day at -35. And there's no block heater in it either. Silly Southern Ontario purchased vehicle... lol
Hardy is offline   Reply With Quote
Old 02-16-2015, 04:12 PM   #31
ricerocket93
At -45 this morning, it did not start. Time for a little road trip to the dealership!
ricerocket93 is offline   Reply With Quote
Old 02-16-2015, 04:19 PM   #32
D_Thissen
D_Thissen's Avatar
Where in the frozen hell do you live? LOL
It was only -28 last night here in Tbay (-33 with the wind, I feel bad for everyone in the GTA mom sent me a picture of the temp in Whitby lol)
I find a block heater helps quite a bit too
Old 02-16-2015, 04:23 PM   #33
With wind chill?????
-28 here yesterday (-40 with wind chill) and mine started like a champ even after not running for 2 days of the same temp!
Old 02-16-2015, 04:45 PM   #34
Pbrown
Drives: 2013 Scion FRS Raven
The real question is????
Why do we live in this shit in the first place? Enough already!!!!! Car started right away this morning. -32
Pbrown is offline   Reply With Quote
Old 02-16-2015, 11:03 PM   #35
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Are you guys counting wind chill when you say temps? Because you know winchill wont affect your battery or your car's ability to start, right? -10 with a windchill of -60 is still just -10
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 02-16-2015, 11:27 PM   #36
D_Thissen
D_Thissen's Avatar
We've had -35 to -40 up here in tbay. She starts, doesn't like it but starts. It starts much better after being plugged in for a few hours though!
Old 02-16-2015, 11:27 PM   #37
Burrcold
Drives: Subaru BRZ Limited
Was going to say the same thing.
Old 02-16-2015, 11:36 PM   #38
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
This is pretty common. Almost every day at work, someone will say "brrr it's -40 out". I check the weather and it's -8 with high winds.
Anyways, back on topic. I have had NO problems starting my car here in Ottawa, regardless of temperature. There is the world's smallest groan when it's really cold out, but after one crank it sounds the same as on a hot summer's day.
pushrod is offline   Reply With Quote
Old 02-17-2015, 07:47 AM   #39
roddy
roddy's Avatar
Drives: '13 Ultramarine
Mine rolls over a little slow at -25 (not including wind chill), but always starts. 340CCA is a bit on the lite side. Considering the size of the battery, it should be around 5-600. Most replacement batteries in that group size will be at least that high.
Old 02-23-2015, 09:38 PM   #40
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
Just tried to start up mine. NO GO. All I get is that dreadful clicking sound. CAA is on the way for a jump. Poor BRZ's been sitting inside my garage (unheated) for approx 5 days.
I did notice the last time it started, it struggled. My last trip was only 20 min. Regret not driving it longer to charge. :/
chermo12 is offline   Reply With Quote
Old 02-23-2015, 10:07 PM   #41
N234
N234's Avatar
Drives:
Living on the GTA and driving to Barrie, the Sube sees lots of -20. It might be a little slow to start but it starts every time.
I release the clutch pedal gently. I once dumped the clutch in neutral and that alone stalled the engine.
N234 is offline   Reply With Quote
Old 02-24-2015, 10:46 AM   #42
PMPB
Drives: BRZ Sport-tech
I started my car today, it sat since Friday the 13th. (10 days no starting)
It fired right up, first shot. (Manual w/ pushbutton start) It was rolling over slowly due to -17Celcius (not incl. wind chill).
The transmission fluid was so thick, the gear selector felt like it was set in molasses. Then when I let out the clutch so I could go clear the snow off, the rpm dropped to the point where the car started shuttering. Checked for the 3rd time that I was in fact in neutral, and let the clutch out much more slowly so the computer could increase the revs as I let out the clutch.
PMPB is offline   Reply With Quote
Specs of the STOCK battery?? stevo_12v Electronics | Audio | NAV | Infotainment 74 10-31-2017 05:45 AM
Nav question for Canadian BRZ owners Burrcold CANADA 16 07-07-2013 04:04 PM
Canadian-based Forum For FR-S/BRZ Owners! DaJo CANADA 11 03-28-2013 12:39 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
