CANADA Canada
Old 09-08-2013, 11:03 AM   #1
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Warning to Canadian owners about stock battery
The stock battery fit to manual transmission Subaru's in Canada is only 340 CCA.
That is hopelessly inadequate for most of Canada.
Subaru makes and stocks a 640CCA replacement battery which you can get if you complain loudly enough after your Subie won't start in cold weather.
Suberman is offline   Reply With Quote
Old 09-08-2013, 11:05 AM   #2
Muskokan
Drives: white Sport-tech
Good call, they replace yours? How bad was it last winter?
Coming up on my first muskoka winter with it.
Muskokan is offline   Reply With Quote
Old 09-08-2013, 11:42 AM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Thankfully the 0w20 oil makes is pretty easy on the starter/battery, cranks as easy as 30 as -30. But I know some places get colder than that.
Rayme is offline   Reply With Quote
Old 09-08-2013, 11:54 AM   #4
davidp
Drives: BRZ Limited
mine started at -38 last winter .. it cranked a bit slower but fired up right away
davidp is offline   Reply With Quote
Old 09-08-2013, 07:14 PM   #5
stateless
Double Dragon
stateless's Avatar
Drives: 2013 6MT BRZ Limited
Good to know! I had no problem with mine through last winter parked outside with no block heater (condo parking had no plugin anyway). Then again, there weren't that many cold days last year, and this is going to be its second winter. I think I'm going to see how it does this year and either get a Costco or AMA battery for even more CCA.
stateless is offline   Reply With Quote
Old 09-09-2013, 10:13 AM   #6
Suberman
Not yet but I'm guessing they'll have to.
Mind you, Yellowknife gets much colder than Calgary so maybe, just maybe 340 CCA might be just enough. Mine is not my daily driver so I don't need it to start for sure at my home location. It's not my ski car either!
Old 09-09-2013, 03:53 PM   #7
wparsons
wparsons's Avatar
I had zero issues with mine last winter, but I'm in the GTA, not way up in cold country
flickr
Old 09-09-2013, 05:45 PM   #8
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Mine started all winter long in Saskatchewan, sometimes after sitting for months. Note our -30,40 degree temperatures and average round -25
Old 09-09-2013, 11:48 PM   #9
Suberman
Good to know. It is possible my daughter's car was delivered with a duff battery.
Still, 340 CCA is pretty wimpy for minus 40C.
Old 09-10-2013, 12:03 AM   #10
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
had no problem last winter, only one time, started hard... -35.... but started still!
Walla Walla is offline   Reply With Quote
Old 09-11-2013, 01:48 AM   #11
stateless
Double Dragon
stateless's Avatar
I agree, that's pretty wimpy for Canada. It seems to work initially for most, but I worry about the second or third year.
Old 09-11-2013, 12:42 PM   #12
ymboc
ymboc's Avatar
I did have a problem a couple times with moisture/frost on the terminal closest to the outside fender.
Once I cleaned up the terminal & frost it worked right away.
ymboc is offline   Reply With Quote
Old 09-11-2013, 03:26 PM   #13
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Two solutions.
1) Switch battery.
2) Move.
I chose the second in 1998. Left Winnipeg and came to Kelowna. No regrets!
Enemies is offline   Reply With Quote
Old 12-30-2013, 01:34 PM   #14
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
2nd winter with mine. Had some sluggish starts, and then one morning it was totally dead (garage, but unheated and -30). Positive there were no lights/draw were on, but car was sitting for 4-5 days.
Trickle charged it, and it's been good since, dealer said it was fine. Tempted to get a 700cca from Walmart for 70 bucks just for piece of mind (and a few more lbs)
Khyron686 is offline   Reply With Quote
Specs of the STOCK battery?? stevo_12v Electronics | Audio | NAV | Infotainment 74 10-31-2017 05:45 AM
Nav question for Canadian BRZ owners Burrcold CANADA 16 07-07-2013 04:04 PM
Canadian-based Forum For FR-S/BRZ Owners! DaJo CANADA 11 03-28-2013 12:39 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
