Old 02-14-2016, 07:42 PM   #29
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
If you are doing rolling measurements strung along several back-to-back fill-ups, the errors resulting from discrepancies in the exact amount of fuel you put in pretty much approach zero, though. So luckily you don't have to worry about those errors in your calculations.
Stang70Fastback is offline   Reply With Quote
Old 02-14-2016, 09:19 PM   #30
extrashaky
Drives: 2014 BRZ Limited
Assuming you filled the tank to exact capacity (13 GAL), then drive exactly one mile, it would be 0.076923...MPG
Practically though, you would most likely be marginally worse than that because fuel capacity does not normally take into account the fuel filler so you would burn slightly more that 13GAL. Also, I'm not sure if capacity is listed in USABLE fuel or overall capacity when talking cars.
The tank is 13 gallons. Only 12.5 is usable fuel. The tank has a 1/2 gallon area that is not accessible so that sediment and water will not be taken up into the fuel line.
Just FYI.
Old 02-14-2016, 09:32 PM   #31
Stang70Fastback
A.K.A. Starlord
I've filled up with 12.3 gallons on a road trip. That was without forcing any fuel in after it clicked, lol. If what you say is true, then that was a close call, lol (I was looking for NOT Sunoco and that was all they had along the highway, lol.)
analysis, brz, data, miles per gallon, mpg
Oil Analysis - 1st oil change R L Newb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 375 11-19-2021 10:24 AM
CFD analysis of BRZ/FRS rear diffuser Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 78 12-15-2014 06:53 PM
MatLab log analysis ztan Software Tuning 12 12-02-2014 08:19 PM
Used Oil Analysis Results Captain Snooze Engine, Exhaust, Transmission 2 11-21-2013 01:59 PM
