| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Computer Scientist
Drives: 2014 BRZ Limited
For the past 4000 miles, I've been tracking my MPG and comparing it with the dash reading. Once I've collected enough data, I plan to do some sort of statistical analysis. I hope some of you might find this interesting.
Introduction This experiment will measure the average amount of fuel consumed by the BRZ and compare it with the vehicles's measurement. The goal is to determine if the BRZ's mpg reading on the dash is within reasonable error. Later, the effects of different tires on fuel consumption may be tested. Procedure for Measuring MPG To measure the average mpg, first the trip odometer is reset to zero miles after the fuel tank is completely filled. During the next gas-station trip, the gas tank is refilled again completely. The amount of gallons displaced since the last fuel-up is measured by how many gallons it takes to fill the entire gas tank. The miles on the trip odometer keeps track of how many miles were driven with the consumed gasoline. By dividing the miles driven by the gallons of gasoline consumed, an average MPG measurement is obtained. The trip odometer is reset after refueling so another measurement can be made during the next gas station visit. About the Vehicle Tested The car driven is a 2014 Subaru BRZ Limited with a manual transmission. The vehicle is completely stock except for a K&N drop-in air filter. All MPG measurements made so far have been with the factory Michelin Primacy HP tires and 0W-20 synthetic motor oil. Only 91 octane fuel is to be used. Transmission and differential oils have been changed midway through the testing, and the date of the change is noted. Sources of Error Driving conditions such as wind, temperature, air oxygen content, incline, speed, traffic, and gasoline quality vary between measurements. However, these factors can be considered random. Thus, provided a sufficient amount of data (more than 20 measurements), the results are normalized and valid. Furthermore, there may be error when refueling the vehicle. It is unknown if all gas station pumps fill the gasoline tank to the exact same amount every time. This error is small compared the the error from driving conditions. While the vehicle is not being driven, it is possible that fuel in the gas tank evaporates away. This increases fuel consumption without gaining any miles on the odometer, meaning that an experimentally measured mpg would be lower than the vehicle's calculated mpg. Preliminary Results On average, the BRZ's dash reads a MPG measurement of 1.3 higher than the experimentally measured MPG. More data is required to verify this result. Later when I have time, I will determine the confidence of the result. 2-11-16 Update I decided to start modding my car, so the experiment sorta went off on a tangent. What I want to do here is provide the community with some data and give an idea of how certain mods might affect mpg. I'm doing this for fun and curiosity; I'm not trying to make statements like "this mod is bad because it decreases mpg". I couldn't care less if I had lower mpg, I want the power and handling from my mods! This isn't a published research paper or evidence for some court case. There are many factors that may affect mpg (temperature, altitude, humidity, road, incline, tire wear, oil wear, fuel quality, etc). I can't control them all or include every possible condition in my sample. Your results will vary. Here's my updated data table: https://docs.google.com/spreadsheets...P78/edit#gid=0 Please disregard the attached image, it's outdated but it seems I can't remove it.
Keep calm and drive safe
#2 | |
Drives: 2014 BRZ
Pretty interesting. I wish I get this much. I usually average 19mpg
Drives: BRZ DGM Limited
I do the same thing and have found the MPG reported by my BRZ runs ~1MPG over what I calculate. On average 28 around town and 40 on long trips.
I am surprise you are not higher with interstate driving. I usually get 39-42 MPG but that is when I drive 600 miles one on day. |
A.K.A. Starlord
Drives: 2015 Series.Blue
Well considering I've done the same thing with my car, and after each tank my car also had read exactly 1.5 MPG higher that what I had actually gotten, I think we can confidently say that the on-board computer is slightly on the optimistic side...
I've been tracking since I got the car (~15k) and it reads anywhere from 1 - 2.3 over calculated. I use the dash indicated avg just to get a feel for how well I'm doing but certainly don't/can't count on it.
Drives: 2013 ultramarine Scion FR-S
I've been using fuelly since I bought my car. Every on board trip computer I've ever compared to has been more optimistic than what fully reports at each fill up.
Drives: ‘16 4Runner, ‘19 Corolla HB
BRZ MPG Data Analysis
There are a ton of variables that impact this study. How worn are your tires? How accurate is the gas pump? How repeatable is the mechanism that causes the pump to stop from station to station? My read outs are all within 5% or so. That isn't big enough to get wrapped around the axle.
![]() Sent from Tandy 400 |
#9 | |
What I'm saying is that he can't conclude that the computers in BRZs generally record 1.5 mpg higher than reality based on one car and one driver. He can only conclude that that outcome holds for him. If he wants to extrapolate to the entire population, he needs to select a desired confidence interval, calculate an appropriate sample size and test a sample large enough to generalize to the entire population. How do we know from his experience that other people are not getting a 5 mpg difference? How do we know that some people aren't getting better mileage than the computer suggests? The biggest concern I would have about relying on his numbers is that some people here have reported some rather low mpg readings from the dash without actually doing the math. I suspect that in at least some of those cases, the error is going the other direction, and they're actually getting better gas mileage than the car is telling them. But if they rely on his analysis, they'll think they're even worse off than they really are, because his analysis is only for his car and isn't applicable to their cars or driving habits. Despite the quasi-scientific approach, this is still just anecdotal evidence at this point. |
#10 |
Drives: N/A
I have 14,617.1 miles on my 14 BRZ at the last fill up and 62 tanks of gas. 58 of those were at the same station and the vast majority at the same pump around 6:30am.
The dash indicates 1.17 higher on average than calculating how much it takes to "fill" the tank. here's a quick summary miles - 14617.1 gallons - 567.05 avg mpg - 25.78 $/g - $3.1805196 cost- $1,803.52
2014 BRZ, SWP, OFT, Kosei K4R 17x7 with ZII SS
#11 | |||
Computer Scientist
Thanks everyone for your input so far.
The "mostly interstate driving" measurements may include 10 to 20 city miles.
#12 | ||
There is also a geographical element. People in different parts of the country are using different fuels. For example, it could be that the computer was calibrated using fuels available in California during the summer months, and during all other times of the year and in different locations the additive package throws off the calculation. You also have the problem that some people live in relatively flat places (like me), while others live in mountainous areas. Altitude will also make a difference, since 91 octane at 5000 feet behaves like 93 octane at sea level. To do this right, you'd have to control for as many of these variables as possible. Or control for the big ones and then try to explain the outliers. That's okay, but... Quote:
So I still think the only generalization you can make at this point is that we can't rely on the mpg calculation from the car's computer. |
#13 | |
A.K.A. Starlord
We don't need everyone to go to the same stretch of the same road where we will install a dummy robot which will drive each car the exact same way, but only when the temperature is the exact same, and the wind is exactly the same, and the ground is the exact same temperature, and only after mounting the exact same tires, and taking out all of the extra custom modifications people have made, and re-installed OEM lighting so that the parasitic drag on the engine is the exact same... ...I could continue, but I think we all know that none of our cars is the same, and that none of these tests, no matter how detailed we try to be, are going to account for anywhere NEAR the proper amount of variables that might come into play. However, if enough people do the test over several tanks of gas, we will eventually get a pretty good idea of a general tendency of the on-board computer to over/underestimate fuel consumption. |
#14 | |
Computer Scientist
To make this more interesting I will later use this average mpg data and compare it to my average mpg after changing tires, because I am interested in how tires can affect mpg. I will use a large sample data in attempt to normalize the data so that it can be compared without worrying about all of the variables. There may be issues such as "the new tires received more city driving than the Primacy tires did," or "the new tires were driven during a different season," and that's why I record dates and often take notes about my data. I could sift through the data and pick out only mpg measurements made from mostly interstate driving trips and compare those. @Stang70Fastback extrashaky's criticism is constructive and good, it will help me perform a better experiment. However, I think there just may have been some miscommunication in what I'm trying to accomplish here.
| Tags |
| analysis, brz, data, miles per gallon, mpg |
| Oil Analysis - 1st oil change | R L Newb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 375 | 11-19-2021 10:24 AM |
| CFD analysis of BRZ/FRS rear diffuser | Wonderbar | Cosmetic Modification (Interior/Exterior/Lighting) | 78 | 12-15-2014 06:53 PM |
| MatLab log analysis | ztan | Software Tuning | 12 | 12-02-2014 08:19 PM |
| Used Oil Analysis Results | Captain Snooze | Engine, Exhaust, Transmission | 2 | 11-21-2013 01:59 PM |
