#4467 |
Drives: Toyota GT86
I wouldn't think so.... Might be worth getting the car on some jack stands and jacking up the rear suspension and look/listen for anything strange as you compress and uncompress the shock
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#4468 |
Drives: 24 GR Yaris, 23 GR86
Funny enough I've been told by the EU dealer that the've had similiar issue with Clubsports for MX5 and after inspection at KW Germany apparently they got the coilovers back as working properly. Obviously I'll have them checked again but I kind of doubt that I'll find anything suspicious.
#4469 |
Anti stance.
What does, "going through bumpstops" mean?
#4470 |
My bad - I meant speed bumps. Edited original post already
![]() Honestly I'm not sure what to do with it further on. All suspension component has been checked for proper torque as well coilovers which are set just like manufacturer supplied manual suggested. Car is lowered just 20mm. It's literally a sound that you can hear while standing near speed bump and car passes through it but in my case it's very clearly hearable inside cabin even with rear seats up. I was just wondering if it's even unusual for KW V3 style coilover. |
#4471 | |
Drives: 2017 BRZ PP, 2004 WRX
Did you ever figure out what this was?
#4472 | |
#4473 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#4474 | |
22mm front 18mm rear. - Andrew |
#4475 |
Andrew beat me to it!
#4476 |
Are pillowball front lower control arm bushings worth it? I'm going to freshen up the bushings on the front of my car and was wondering if anyone has any experience with these bushings. I'll be doing a lot of autocross this year which is why I was considering pillow balls.
Bushings==> https://hardraceusa.com/collections/...6-fr-s-1st-gen |
#4477 |
Drives: 22 BRZ limited
Have you looked at your class to see if they're allowed?
#4478 | |
Someone double check me though. I never see pillowball bushings on any STX (now DST) build list. If there was any advantage and if they were allowed, people would be running them. Edit: Here you go... Suspension bushings may be replaced with bushings of any materials as long as they fit in the original location. Offset bushings may be used. This does not authorize a change in type of bushing (e.g., ball and socket replacing a cylindrical bushing) or use of a bushing with an angled hole whose direction differs from that of the original bushing. If the standard bushing accommodated multi-axis motion via compliance of the component material(s), the replacement bushing may not be changed to accommodate such motion via a change in bushing type, for example to a spherical bearing or similar component involving internal moving parts. Pins or keys may be used to prevent the rotation of alternate bushings but may serve no other purpose than that of retaining the bushing in the desired position.
#4479 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Spherical anything in the front LCA is not legal in most pro-solo classes.
That said, I have those exact bushing in my car now, and the ride was noticeably worse. Also thought I wasn’t worth it, until I took a corner. The more the you load the front, the better it feels. With sticky tires they really make a difference in feel. Overall grip/performance - not so much. Sent from my iPhone using Tapatalk |
#4480 |
Drives: 2023 BRZ, 2018 Golf R 6MT
So uh... what's your go-to option for fixing the chassis threads that the bolts at the front of the rear subframe go up into? >.>
One side is beyond a thread chaser (I tried, and I made it worse). Quite possibly beyond a tap at this point, too. Other side might be re-tappable and I have one on the way to try. I necro'd the thread about it, but figured I'd ask here to hopefully get some advice from a professional shop. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
