Old 01-20-2016, 11:49 AM   #43
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I know the oem wheel/tire combo is 41.4 pounds.. So The oem wheel is maybe 20 pounds.
I wont buy wheels that are over 18 pounds each. Ideally I want to get some in the 16 pound range hahahaha. IDK why I have this mind set that I need light rims, thats why I haven't got new ones yet .
Old 01-20-2016, 11:51 AM   #44
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Lol most lightweight wheels cost some major $$$ at least the ones I find appealing visually
Instagram: trevor.parque
Old 01-20-2016, 11:53 AM   #45
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah tell me about is. Rims I like start in the 4K USD range I really like the looks of the ones you got. Can't wait to see them on your car
Old 01-20-2016, 12:01 PM   #46
Teseo
Drives: frs
Rays looks on our cars
Old 01-20-2016, 12:08 PM   #47
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
You gota call them "Wheels" now as per @jawn
Old 01-20-2016, 12:10 PM   #48
MisterSheep
Killed Scion
I believe they make them in 17x9 +40 5x100 but I'm trying to look up the weight now..
the 17x7 weighs roughly 17 pounds
Old 01-20-2016, 12:12 PM   #49
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
I too ran into something similar.
My first setup
Avid AV-20's Staggered
18x8.5 et33 245-40
18x9.5 et38 255-35
I loved the look but there was a definite difference in acceleration and the overall feel through corners. Being an idiot was easy, I could use both feet on the gas pedal through almost any turn but it wasn't as fun. I drove it like this for about a year until I found the coveted rpf1'z.
So I ended up going back to 17's.
17x9 et35 Square 245 40 Hankook evo2's. IMO I still have the grip and the ascetics I wanted without having sacrifice anything. I purchased the avid wheels because I couldn't afford what I wanted at the time. If given the chance I would wait and buy the wheels you want. Do it once and do it right.
Don't settle
tumbla.jr is offline   Reply With Quote
Old 01-20-2016, 12:20 PM   #50
Cole
Not a troll
Cole's Avatar
These wheels are too heavy and too pricey for me to even consider. I spent just over 1k CAD and got wheels that weigh 16.8 pounds a piece for 17x9. Mind you, they aren't as pretty as some other wheels, but they're better value than many other wheels.
I probably wouldn't have said no to the deal you got either. Worst case you could probably flip them for a couple extra bucks.
Old 01-20-2016, 12:32 PM   #51
strat61caster
strat61caster's Avatar
17x9 RPF1's are under $1,100 USD shipped new from TireRack claiming 16 lbs. Doesn't help you much, but with tires I believe they come in just under 40lbs so a hair lighter than stock for the same money OP's talking.
ineedyourdiddly
Old 01-20-2016, 12:37 PM   #52
Cole
Not a troll
Cole's Avatar
Yeah, but 1100 USD equals over 1600 CAD. Not to mention the **** pain that's shipping and taxes on top of that. As it is with the wheels I ordered, I'll have paid around 1800 CAD all in for them with tires, mounting and balancing.
Edit: Doh, misinterpreted your post. Nothing to see here.
Old 01-20-2016, 12:51 PM   #53
Ashikabi
Ashikabi's Avatar
If RPF1s are barely lighter than stock... why does anyone spend the money to upgrade?(real question. I never looked it up before, I just assumed they were significantly lighter)
Old 01-20-2016, 01:18 PM   #54
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
It's ~4 pounds lighter than stock despite being 2" wider. That's not insignificant. For more weight savings, 17x7-17x8s are also available.
jawn is offline   Reply With Quote
Old 01-20-2016, 01:22 PM   #55
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
17x9. For the width.
Old 01-20-2016, 02:10 PM   #56
strat61caster
Elaborating on the other two, you get a 245 wide tire on a 17x9 vs a 215 wide tire on a 17x7 for the same weight, if not slightly less on the RPF1's I believe. 17x8 and 17x7 RPF1's will both be lighter than the stock when combining wheels and tires.
i.e. this guy's 17x7's w/ 225 tires weighs in 2.8 lbs lighter than the stock 17x7 w/ 215's, another guy weighed in a bit heavier with different tires.
http://www.ft86club.com/forums/showthread.php?p=818060
There are lighter wheels out there but the costs quickly start to climb into well over $2k a set for just wheels, meanwhile RPF1's will arrive with tires on your doorstep for under $2k. Honestly it speaks to how despite cutting corners in the 86 to keep costs down, the OE wheels aren't half bad.
ineedyourdiddly
265's square FAER Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-22-2014 05:14 PM
235/40/18 on 18x8.5 +47 Square? Ozzie Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-27-2014 02:06 AM
Square vs staggered kosoku Tracking / Autocross / HPDE / Drifting 60 08-20-2013 05:02 PM
18x18.5 +22 square?? abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 05-11-2013 12:06 PM
Square or Staggered? dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 02-02-2012 10:40 PM
