Old 08-14-2013, 06:19 PM   #43
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Sportsguy83 View Post
What did you do to the Perrin intake bracket? I added some washers to try and make it straighter... But its a pain in the ass and I always recheck that it hasn't slip as the connection is not the best.
I didnt even use it. I made a new one out of some sheet metal i had. Bent, drilled, threaded and painted. Basically i made something that looks like a stretched "z", this allowed me to use the factory hole and the perrin hole. They are about 1.5-2 inches apart. Ididnt like bending and stretching anything, and basically installed it to the avo inlet pipe, and then measured and created a bracket so it held securely, but not put any stress on the avo part.
Sorry, no pics. Next time i am in there working on it, if visible i will take a pic. Nothing special really.
gdrider77 is offline   Reply With Quote
Old 08-15-2013, 03:03 AM   #44
DAMotorsports
Drives: 2013 Scion FRS "Raven"
@gdrider looks great keep up the good work. if you feel like hiding the vent lines there is room under the intake for them to hide. that one way we kept the low key look
DAMotorsports is offline   Reply With Quote
Old 08-27-2013, 04:56 PM   #45
gdrider77
gdrider77's Avatar
Curious what you mean by this? got a pic?
Old 08-27-2013, 08:01 PM   #46
gdrider77
gdrider77's Avatar
new goodies arrived today.
GRimmspeed Masterbrake cylinder brace
Grimmspeed Hood lifts
Cusco drift knob.
Yay!
Old 08-27-2013, 09:02 PM   #47
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
He means the vent lines going to the catch can to rout them behind the intake manifold instead of going on top of it.
Old 08-27-2013, 09:32 PM   #48
gdrider77
gdrider77's Avatar
Thats what i thought, i considered running them underneath as well. Might lookinto that next time im under there....Might need to get a bit longer line for one of them.
Old 09-10-2013, 08:01 PM   #49
gdrider77
gdrider77's Avatar
Made a custom mount for the Perrin intake to better line up with the AVO kit.
@Sportsguy83, here are the promised pics!
Old 09-10-2013, 08:12 PM   #50
Sportsguy83
Drives: Limited BRZ
Awesome I did something similar. Got the idea from you. I had to hack into it a little more because Robispec radiator being thicker, the bend below the intake to fit it right over the stock radiator does not work with the thicker Robispec.
I will reply to your PM soon when I get back on the computer.
Sent from my HTC One X using Tapatalk 4
Old 09-11-2013, 11:09 AM   #51
jx86
Drives: -
Are you using the grimmspeed ebcs? Any thoughts?
jx86 is offline   Reply With Quote
Old 09-11-2013, 04:13 PM   #52
gdrider77
gdrider77's Avatar
I am (kind of) If you look in the engine pics, i have both the @GrimmSpeed EBCS and MBC. The EBCS does not work, so using the mbc for now. My tuner as well as another tuner has tried unsuccessfully to get it working. Others on this forum and other places have had no good luck with the EBCS as well from what i have read.
This does not seem to be isolated to just the @GrimmSpeed EBCS but pretty much all of the EBC units.
Most likely will be pulling it out and sticking with the manual. REally dissapointing, as we wanted to get the EBCS working properly, but i just spent about 10 hrs on monday working with my tuner, in his shop, and no luck. He even called ecutek, as well as another popular tuner on this forum (not going to mention name) and no luck.
Old 09-11-2013, 04:32 PM   #53
sw20kosh
Drives: 2013 Black FR-S
I was able to get my Perrin CAI to fit with Robispec radiator. I had to remove that plastic "air diverter" thing though. It is definitely a tight squeeze.
Old 09-11-2013, 04:40 PM   #54
Sportsguy83
Drives: Limited BRZ
Maybe it is because I adjusted the Perrin CAI's mounting point to make it be angled straight instead of looking towards the hood.
My radiator cover tee would not bolt back on.
Old 09-12-2013, 12:33 PM   #55
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Hmm, I was told by someone that the EBCS is simple to tune in EcuTek and that anyone considering any option other than an EBCS was an idiot. I guess he was wrong.
Old 09-12-2013, 01:40 PM   #56
jx86
Drives: -
Relax! I guess it's more of a personal preference thing. Don't mean to hijack OP thread, but how is the GFB working out for you? It certainly looks interesting. I'm undecided between that and the Grimmspeed/Tactrix EBCS but I will admit as per what that "someone" said, that the idea of an all inclusive set it and forget system is pretty enticing because I have limited knowledge on all matters turbo. Then again, I'm not sure I want to disable my EVAP because I'm worried of long term effects, if any.
To double confirm, does the GFB Ebc clear memory/settings upon battery pull?
avo, bov, brz, turbo, uel
2013 Hot Lava FRS "Drift build" THA STI GUY Member's Car Journals 58 04-25-2015 05:55 PM
The RaceComp Engineering BRZ "Clubsport" Build Racecomp Engineering Member's Car Journals 100 12-18-2014 03:18 PM
KO's Raven FR-S Build: Name "Raven12s" KO Member's Car Journals 3 07-18-2013 03:09 AM
Whiteout "8ROKU" build from Dallas (Frisco) jacobzking Member's Car Journals 23 06-27-2013 02:56 AM
Norsamerican's WRB BRZ aka "Backdraft" Build norsamerican Member's Car Journals 2 06-20-2013 08:16 PM
