Old 06-23-2013, 02:03 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
AVO "Stage 2" Build
So this thread is for my new AVO turbo build. Been working with Paul and getting this thing all together. Preliminary but man this thing is a great kit. Running into some logistic issues initially, but have to say, Paul has been great, must never rest. I literally got a new tune from him like at 1am in the morning from him on a Sunday!
I think he understands that for many of us the joy of working on our cars and being limited to off-hours and weekends. Really tries to accomodate whenever possible. There now that my little AVO plug is done, on to the install.
I am in my garage typing this, so still very much in the middle of installing everything, but wanted to get the post and placeholder in place.
I will get more info, pictures, dyno vid and more soon.
Sat-Sun - Finish putting turbo together, check for leaks/problems.
Monday-Tuesday, New injectors and Fuel Pump, possibly MBC or EBC.
Weds...on the dyno and dual tuned for e-85 and 91. Not sure on boost levels yet, We will figure that out more when being tuned.
This week research clutch and brakes. and then order those for install.
Teaser pics and more pics and better writeup coming soon. Apologize for these pics, taken with my cell phone, so not the greatest.
Parts Arrive, Avo turbokit, Avo bov, Avo oil catchcan, 3-Bar Map sensor
Engine Before, Injen intake
In progress
Datalogging and setting up AEM failsafe
gdrider77 is offline   Reply With Quote
Old 06-23-2013, 02:15 PM   #2
jamesm
why replace the clutch? can't the stock clutch handle the avo kit? thanks for the post, i can't wait to see what it looks like all finished!
one question: what is the difference between stage 1 and stage 2 of the avo kit?
Old 06-23-2013, 04:20 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It can handle AVO kit stage 1. Stage two can still be handled by stock clutch, but not for a long time.
Difference between Stage 1 and two:
Stage 2 Kit Hardware:
The AVO Stage 2 Kit utilizes all of the hardware of the Base Stage 1 kit, and adds on the following components:
AVO 7psi Actuator
3-bar MAP Sensor
AVO Street Breather Tank system with Turbo PCV Valve Upgrade
AVO Ceramic Coated Cross-over Pipe
AVO Stainless Steel Front Pipe with 5" Metal Cat
Stage 2 Base Map [EcuTEK]
Old 06-24-2013, 03:08 AM   #4
Djen
Drives: GT86
Whats the Weight of this kit sir? I mean whats the shipping weight was?
Djen is offline   Reply With Quote
Old 06-24-2013, 05:59 PM   #5
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Interested to see the gains on the stage 2. I'm number 7 on the Order list for the month of July, can't wait to put this kit in.
Ny Brz is offline   Reply With Quote
Old 06-24-2013, 11:46 PM   #6
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
How much did it cost you?
Edit: im wondering if someone has already solved the fuel starvation when cornering.
JackSmiley is offline   Reply With Quote
Old 06-25-2013, 01:47 AM   #7
Ny Brz
Hella Flush
Ny Brz's Avatar
Would you mind a pic of the bov outlet, I have a spare blitz bov that I wanted to use it just want see how the outlet looked.
Old 06-25-2013, 02:58 PM   #8
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
sub'd
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 06-25-2013, 04:50 PM   #9
gdrider77
gdrider77's Avatar
Well. Kit all together and took for test run with stage1 base map. Seem to work well. Really starts to kick in around 2500 or so. I installed the stage2 map and upgraded 3bar map sensor. Took for a new run and noticed a goofy sound.....exhaust leak...ugh. After getting under there with a steth, determined its leaking from both the header gaskets...
So pulled the turbo/headers off and ordered some new gaskets from subaru. In the meantime put in new injector dynamics 1000cc injectors and a new Deatschwerks fuel pump. Doing an AEM failsafe, so will be wiring in a boost solenoid for the failsafe feature to cut to wastegate spring pressure on alarm.
Also since i have the turbo and headers back off, going to wrap them and add a turbo blanket. Hope to have this back together in the next 2 days or so, then off to the tuner for dyno tune.
Will be doing a dual map tune ECU controlled boost, user switchable with cruise control to toggle between e-85 and 91. Looking to do around 11-2 psi boost on this. More to come.
This is quickly ballooning out of control, and man...keep spending money.
Old 06-25-2013, 04:55 PM   #10
gdrider77
gdrider77's Avatar
See if this works for you.
Old 06-25-2013, 05:05 PM   #11
Ny Brz
Hella Flush
Ny Brz's Avatar
Thanks for the pics, do you think you will be posting of any vids of in/out cabin noise, like to know how that thing sounds.
Old 06-25-2013, 05:10 PM   #12
jamesm
that's a pretty bov. i almost wish i would've went with a recirc. keep it low profile
Old 07-07-2013, 11:57 PM   #13
gdrider77
gdrider77's Avatar
Been at my tuner for 2 weeks now getting finessed. Doing a dual tune 91 octane and e-85. Using map switching via cruise control switches. Probably around 7-9psi on 91 and 12-13 on the e-85.
Hope to have dyno stats, vids and pics soon. Suppose to be done in the next few days. 91 tune is done and stable, but really tweaking the e-85 tune.
Old 07-08-2013, 12:01 AM   #14
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
did your breather tank come with the oil cap feeler replacement?
86_ZN6 is offline   Reply With Quote
avo, bov, brz, turbo, uel
2013 Hot Lava FRS "Drift build" THA STI GUY Member's Car Journals 58 04-25-2015 05:55 PM
The RaceComp Engineering BRZ "Clubsport" Build Racecomp Engineering Member's Car Journals 100 12-18-2014 03:18 PM
KO's Raven FR-S Build: Name "Raven12s" KO Member's Car Journals 3 07-18-2013 03:09 AM
Whiteout "8ROKU" build from Dallas (Frisco) jacobzking Member's Car Journals 23 06-27-2013 02:56 AM
Norsamerican's WRB BRZ aka "Backdraft" Build norsamerican Member's Car Journals 2 06-20-2013 08:16 PM
