Old 02-20-2013, 02:58 AM   #57
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Originally Posted by RYU View Post
Actually I'd like to also see an r1 vs r2 time attack!
I second that.. if I end up ordering the Eibachs it will be the R1s for me.. i feel that the R2s are too adjustable for the streets lol
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 02-20-2013, 03:04 AM   #58
ayau
Drives: Some rust bucket
Assuming spec alignment... Whoever set the dampers up better. Assuming mike can tune them to his liking... Who the hell knows.
Factory coilover spring rates:
Tein SRC: 11/12kg
Eibach R2: 4.9/6kg
I feel like the SRC has an advantage if we're talking about a stock coilover setup.
Old 02-20-2013, 03:14 AM   #59
D1cker
Drives: B9 S4/ND2
out of the box I think the SRC will have the advantage, but you're paying quite a bit more for them. I'm down to run at the next FT86 Cup event against any of the R2 guys
D1cker is offline   Reply With Quote
Old 02-23-2013, 12:46 AM   #60
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Originally Posted by ayau View Post
I was torn between the KW Clubsport and the Eibach R2. There seems to be more transparency with Eibach and @Jackson, and that's why I chose the R2 over the Clubsport.
@Jackson, I read some reviews that each R2 damper gets dyno tested before they're shipped. Can you verify this?
Yes, every damper is dyno tested before being boxed and shipped. I'm currently working with the engineers to print out each dyno sheet with matching serial numbers to include with each kit.
As for the KW v3 vs. Tein SRC vs. Eibach R2...I'm down to help out anyway we can.
Jackson is offline   Reply With Quote
Old 03-04-2013, 04:55 PM   #61
ayau
Are we closer to shipping ETA?
Old 03-05-2013, 02:01 PM   #62
Jackson
Jackson's Avatar
The ETA I've been told is for mid March...next week.
Old 03-05-2013, 06:08 PM   #63
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Tein SRC: 11/12kg
Eibach R2: 4.9/6kg
I kinda like somewhere in the middle and run 6k/7.7k on my GC/koni race setup, and they are red eibach coils, so I wonder how that would feel on your r2's...
heck If where was a way for me to make it out we could have back to back r2 vs src vs GC-race vs who knows, sounds like a mini 86 Tech festival in the making tho...
Huehuecoyotl is offline   Reply With Quote
Old 03-06-2013, 01:48 PM   #64
CSG David
CSG David's Avatar
Spring rates is just a surface level indicator of what the suspension can do. Valving is where the magic lies.
Old 03-06-2013, 01:52 PM   #65
Huehuecoyotl
you got it!
Old 03-06-2013, 02:29 PM   #66
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tein SRC: 11/12kg
Eibach R2: 4.9/6kg
I thought the src normally came without springs? Regardless I assumed spring rates would be equal so you could truly compare just the stock damper itself. ie make everything else equal.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-06-2013, 02:45 PM   #67
The SRC do not come with springs, but everyone needs springs to put them on, so there's a default
The default happens to be 10k/12k, but the dampers will support much softer and/or stiffer springs. Anywhere from 8k to 14k.
Old 03-06-2013, 02:51 PM   #68
brianlo622
brianlo622's Avatar
Mid March is when the product will be on the shelves correct? (assuming these are not built to order)
悪魔のハチロク
Old 03-06-2013, 05:09 PM   #69
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
lol obviously everyone will need springs
My point was the rates should be equal for any test if we really want to isolate the comparison solely to the damper itself. Let the same user setup both to their preferences.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-06-2013, 07:03 PM   #70
ayau
How can you quantify the quality of valving? Shock dynos?
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 11:59 AM
AST's at buttonwillow raceway Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 07-02-2013 04:16 PM
◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 48 06-07-2013 03:19 PM
Buttonwillow Track Day Heads-Up sv_dave Southern California 3 09-08-2012 10:20 AM
