Drives: 4 wheels
Eibach Multipro R1 and front and rear sway bar installed
I have some pictures of Eibach Multipro R1 and front and rear sway bars. The guys from Eibach are very happy with their work and tell me the car fundamental characteristic hasn't been change just improve. The sway bar are front and rear, but currently it only rear adjustable because the front is under revision. I haven't been able to really drive to give honest feedback yet. Here some pictures.
Drives: 2013 86 white
Look awsome. I will wait for final products and put it on mine.
Site Moderator
Drives: Stuff
I'm waiting for the r2
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
Drives: GT86 Soon! Previous: Aw11, Ae111 Ae
Looking good but looking forward to any changes in handling ability
Drives: Argento
waiting for the final specs...
Drives: E46 M3 (daily) / EG Civic (track)
We're looking forward to your feedback.
Our Eibach Engineers have the kits dialed in 98% so far. We want to do more testing before releasing the final specs. However, here are the part numbers for each kit for reference. Pro Street-S - Mono-Tube, Height Adjustable only Part# 82105.711 Multi Pro R1 - Mono-Tube, Height Adjustable, 7 clicks of rebound adjustment Part# 82105.712 Multi Pro R2 - Mono-Tube, Height Adjustable, 7 clicks of rebound, 10 clicks of compression, remote reservoirs front and rear. Part# 82105.713 All kits will include our standard coilover springs with pre-determined rates. However, different spring rates can be purchased to set up the coilovers to the driver's preference. |
Pro R1 with just rebound adjustment is pretty awesome. How silly are we thinking the stock spring are going to be? 400lb front and rear?
Drives: 2006 Subaru LGT
No dust boots?
Senior Citizen
Drives: Scion FR-S
Any specs on the front sway bar?
Is the front solid or hollow? Thickness? Also for the R2 shocks, are the shock bodies themselves the same dimensions as stock? If so, there may be a market for us Stock Class guys. Would need custom mounts to hold the stock springs though. |
#10 | |
Site Moderator
Drives: Stuff
Also important IMO is that these dampers are built in the US and rebuildable in the US, which will mean quick turn around times when the time comes (and it will, every damper needs rebuilds). I'll keep pushing Jackson to post shock dynos when the time comes
-Dave
#11 |
Absolutely Dave, I live in Orange Country and I love that they are rebound only singles for my recreational track use. These may be the right way to go for me. I am hoping they are soft enough to run a 330-400lb spring... No R compounds here and I want to daily them.
#12 | |
Drives: 4 wheels
I really like that they make everything in the US and also there actual engineers who makes the parts for the car. It not like the parts are developed in China and brought back, and there customers service seem to be top notch. They make their coilovers, springs, and sway bars in house. There an actual equipments that test each new products for quality and control, and they actually get data on the parts they produce. Compared to other companies out there. |
#13 |
No dust boots?
#14 |
No dust boots. Most of our coilovers use multiple seals along the shaft to prevent any corrosion internally. If you plan to really get down and dirty with the car we do offer spring bags that seal around the outside of the spring to keep debris out. A lot of off-road guys use them to prevent mud from packing between the coils and shock shaft.
| Rear/Front Sway Bars on the BRZ | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-24-2013 06:54 PM |
| WTB: Stock WRX 16mm Rear Sway Bar | NYC BRZ | Cars for Sale/Trade | 3 | 09-01-2012 07:36 PM |
| Perrin Rear Sway Bars at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 06-28-2012 11:38 PM |
| AMT rear sway bar bracket | adamturbo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 06-13-2012 12:06 PM |
| STI rear sway bar | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-25-2012 01:58 PM |
