Old 04-27-2014, 10:10 PM   #729
GremlinGSP
Just got my AVO kit installed.Name:  AVO Turbo.jpg
Can you add me to the list of Owners?
GremlinGSP is offline   Reply With Quote
Old 05-03-2014, 03:30 PM   #730
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Trying to get the Stg 2 upgrade actuator installed today. Looks like it is a bit too short to reach the wastegate lever. When swapping the longer arm from the Stg 1 actuator over, it is too long. Does this look like the right actuator, or am I missing something?
FrX is offline   Reply With Quote
Old 05-03-2014, 03:56 PM   #731
onzippy
Drives: 2014 FRS
I'll tell ya, when I got the 8psi it came with the shorter arm also but the rod was the same length as the 6psi. I swapped the short for the long and if fit. Sorry to say yours looks a bit different.
onzippy is offline   Reply With Quote
Old 05-03-2014, 07:59 PM   #732
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
I just had the exact same problem.....had to contact paul at Avo to send me the proper arm. I don't understand...if this is the upgrade for the kit why is it wrong.
brz2013 is offline   Reply With Quote
Old 05-03-2014, 10:43 PM   #733
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Mine didn't come with an arm. I figured I just swapped the original over. Works perfect for me
Old 05-03-2014, 10:44 PM   #734
brz2013
brz2013's Avatar
I feel like we are all getting mismatched stuff. I tried swapping the longer arm on to it but the hole was smaller
Old 05-04-2014, 02:36 AM   #735
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I had the same issue as both of you and didn't even remember it until now.... One more to add to the list..
Old 05-05-2014, 09:58 AM   #736
qtwre
Drives: White FR-S
Well, my turbo was installed Thursday and I made it until Sunday morning before an exhaust leak developed.
When the car starts after sitting for about an hour or longer, it sounds like a turboprop plane for about 30 seconds until I assume things heat up and expand a little to seal it. This is with the Forester XT gaskets recommended in the owners thread.
I was so happy when it was initially installed without one problem. I hope after tightening it down again it will be fully set in place.
qtwre is offline   Reply With Quote
Old 05-05-2014, 10:16 AM   #737
protpibe
protpibe's Avatar
What gaskets did you use ?
Sent from my HTC One using Tapatalk
Old 05-05-2014, 10:23 AM   #738
brz2013
brz2013's Avatar
Lol he's said forester xt gaskets
Old 05-05-2014, 10:33 AM   #739
protpibe
protpibe's Avatar
ah my bad, I misread that. Too early in the morning!
Old 05-05-2014, 12:16 PM   #740
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Probably lost in the translation to English.
Old 05-05-2014, 12:22 PM   #741
Sportsguy83
Drives: Limited BRZ
I bet...
Old 05-05-2014, 04:53 PM   #742
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I bet...
Like most of their installation manual...
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
