Old 02-07-2014, 08:47 PM   #85
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
First of all, thank you for this thread.
I just finished replacing my transmission fluid with Red Line Gl-4 MT-85. The job was a breeze... i took my time and it took no longer than an hour. The transmission fill/drain plugs do not have crush washers, they are solid and reusable. Noticed a small difference after test driving, but i'll know for sure after about a week of driving.
Anyway heres some pics:
The Fluid I used
Immediately after removal
After a quick wipe down
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 02-09-2014, 07:43 PM   #86
qqzj
Drives: MDX, Camry
Quick question where is the best place to buy Motul 300 gear oil? Surprised nobody asked this before.
qqzj is offline   Reply With Quote
Old 02-09-2014, 09:28 PM   #87
BeRZed
http://www.ft86club.com/forums/showthread.php?t=17759
BeRZed is offline   Reply With Quote
Old 02-15-2014, 01:02 PM   #88
CoupedUpSubie
Drives: 2013 BRZ Limited
I am getting ready to change all my fluids over to Amsoil, found this pump at Advance Auto Parts. It fits the Amsoil quarts nicely. It took less then 20 pumps to nearly empty each quart, the end has two barbs on each side which grab the threads holding it in the trans or differential. I bought two as they were only $6 a piece, no cross contamination.
http://shop.advanceautoparts.com/web...ump#fragment-3
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-08-2014, 10:20 PM   #89
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Before/after:
Just FYI washer(s) for rear diff are the same size/thickness. Cheaper of the two is part # 1215710010, just buy two of those.
-alex
Old 04-01-2014, 04:26 PM   #90
mweidner311
Drives: N/A
Cheap Motul Summit Racing and Amazon
I bought mine at Summit. I happen to live close enough to pick it up but they will ship it as well and most of the time they offer free shipping if the order is above $99.
http://www.summitracing.com/parts/mtl-100118/overview/
I noticed other dealers selling and shipping it on here but not for the same price as Summit and with the free shipping and no tax you cant beat it.
Kster1 posted this if you need a case its like $13 a bottle free shipping
[ame="http://www.amazon.com/Motul-3178CZ-12PK-Synthetic-Differential-Lubricant/dp/B004LEWJSW/http://"]Amazon.com: Motul 3178CZ-12PK Gear 300 75W-90 100 Percent Synthetic Ester Based Racing Gearbox and Differential Lubricant - 1 Liter, (Case Pack of 12): Automotive[/ame]
Just wanted to help people find a good deal
mweidner311 is offline   Reply With Quote
Old 04-11-2014, 01:13 PM   #91
jvincent
jvincent's Avatar
Thanks to the OP for the great DIY.
Just finished off my trans/diff fluid swap (Motul 300) and the DIY instructions were great.
My only issue was not positioning my bucket properly to catch the transmission fluid so I had a bit of a spill initially.
Old 04-11-2014, 02:31 PM   #92
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Does anyone have thoughts on motul 300 75W-90 vs motul motylgear 75w-90. All of my searches have only found info that is years and year old, and that suggested the motul motylgear 75w-90 was better.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 04-11-2014, 02:44 PM   #93
jvincent
jvincent's Avatar
Sorry for any confusion, I used the Motul Gear 300, which is 75w90
Sent from my Nexus 7 using Tapatalk
Old 04-11-2014, 05:08 PM   #94
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
So best of the best for a flush tranny / diff / engine oil would be what ? Motul for tranny / dif and amsoil ?
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 04-11-2014, 05:44 PM   #95
GetSource
Drives: 2014 WRB BRZ Limited
I had Motul Gear 300 put in (both trans and diff) by my local mechanic, and it definitely made cold gear changes better. It's still not perfect, but a definite improvement.
GetSource is offline   Reply With Quote
Old 04-11-2014, 05:56 PM   #96
retrosmiths
Drives: Scion FR-S Whiteout
^ This.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-11-2014, 07:51 PM   #97
Simon99
Simon99's Avatar
For me its not really cold shift, but more all shifts .. coming from an Speed and Civic SI, I feel the shifter really needs refinement ..
Old 04-23-2014, 04:36 PM   #98
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
update part number SU003-03626 for the transmission drain and fill washer gasket is the same exact size as hondas transmission drain plug and it costs 2.27 instead of 11 bucks. save some money. hondas part number is 90471-px4-000
hope this helps guys
driftartist is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 09:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 06:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
