Old 04-24-2014, 01:09 AM   #99
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
How do you flush out and change the manual fluid in the reservoir Under the hood? I am seeing some kind of contamination.
texasbound972 is offline   Reply With Quote
Old 04-24-2014, 01:38 AM   #100
FastWhite
Drives: Subaru BRZ Limited M/T
The MT has a drain and fill plug on the trany itself.
Remove the fill plug first, to ensure that you can put fluid in BEFORE you drain the fluid.
There is no reservoir under the hood for the MT. just brake and clutch
And the biggy here, search in the DIY thread and you will find a very good instruction guide on how to do this.
FastWhite is offline   Reply With Quote
Old 04-24-2014, 03:52 AM   #101
retrosmiths
Drives: Scion FR-S Whiteout
This is the instruction guide.
Sent from my phone. Might have typos. Sorry.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-24-2014, 08:13 PM   #102
texasbound972
USMC
Think we are talking about two different things retrosmiths. Name:  uploadfromtaptalk1398381125901.jpg
Size:  25.6 KB this would be the fill spot if it were part of the trans.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Old 04-24-2014, 11:16 PM   #103
retrosmiths
Oh, my bad, sorry.
2013 Scion FR-S
Old 05-12-2014, 01:29 PM   #104
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
by reading this am i correct when i say i need two and a half us quarts for the trans and 1.1 us quarts for the diff ? im going with amsoil just want to make sure i get it right the first time
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 05-12-2014, 01:39 PM   #105
gramicci101
Off Topic
It's 2.2 and 1.3. Either way, fill it until it weeps out of the fill hole, then wait for it to stop trickling out.
@F1point4 wasn't kidding about the transmission fluid shooting out sideways, either, so be ready for that. I cut a half moon chunk out of the side of a 1L water bottle and pointed the mount of the bottle at my drain pan. That let me catch the initial rush of fluid and redirect it down to the pan.
Old 05-14-2014, 01:46 PM   #106
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
You know... One could put in a reservoir if one was so inclined...
I'm not so inclined, but it is a thought.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 05-22-2014, 08:45 AM   #107
mister.bond
Drives: BRZ Subaru
Can someone explain the Difference to me
BETWEEN :
Motul Gear 300 75W90 " LS "
and : the normal Motul Gear 300 75W90 ????
i just bought 4 Litres of the Gear 300 75W90 "LS"
can i use it or is it not good and i must buy the normal Gear 300 ????
greetings to all from the other side of the World ( Germany )
Thomas
mister.bond is offline   Reply With Quote
Old 05-22-2014, 09:09 AM   #108
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
http://www.ft86club.com/forums/showp...6&postcount=12
I'm not sure on the exact differences so maybe someone else can help fill that in. Yes you can use it, but some do not use it in the trans.
BETWEEN :
Thomas
hyper4mance is offline   Reply With Quote
Old 05-22-2014, 09:18 AM   #109
mister.bond
Drives: BRZ Subaru
ok, thank you
to all again please
i CAN USE the Gear 300 75W90 " LS " for my Subbie BRZ Torsen Diff , right ?
so as we have a Torsen Limited Slip Diff, the LS Version must be the right , or am i wrong ?
i hope someone can explain it to me
Old 07-09-2014, 04:07 AM   #110
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
ok, thank you
to all again please
i CAN USE the Gear 300 75W90 " LS " for my Subbie BRZ Torsen Diff, right?
so as we have a Torsen Limited Slip Diff, the LS Version must be the right, or am i wrong?
No you don't need the LS version. See reply below:
Originally Posted by No Limit Motorsport View Post
Use the 75W90 regular Gear 300 for both transmission and differential. The LS is not needed for the torsen type differential that these cars have. It will give no benefit.
This works to the users advantage too, because instead of having to buy 2 liters LS for the differential, and 3 liters for the transmission (5 liters total), you can just buy 4 liters of the same product.
Fizz is offline   Reply With Quote
Old 07-13-2014, 09:32 AM   #111
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
The part of this DIY that explains how to remove the fiberglass plate under the trans should be fixed.
It says to remove only 7 bolts that are in a U formation on the plate (based on the picture), but along the top/front side there are a row of bolts (4 or 5) that also need to come off. If you only take out the 7 bolts as the DIY says, the plate is still attached, dangling from the other (metal) plate. Once you take out the additional 4-5 bolts, you can then remove the fiberglass plate without taking off the metal plate.
It's not hard to figure out but just to prevent people from scratching their head.
Old 07-14-2014, 01:49 AM   #112
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Just followed this guide and wow my transmission shifta like butter now used motulgear 300
thanks!
BRZtoni is offline   Reply With Quote
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 09:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 06:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
