#1317 | |
Yup mine did. I used something to pull the pipe back towards the rad support.
#1318 |
Drives: 86 GTS White
#1319 | |
I would take a look at the charge pipe mount first. Did you install it correctly?
#1320 |
#1321 |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Next weekend. I'm also going to record the logs to delicious tuning during the week...
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#1322 | |
uosɹǝdʎɐl ʇɹǝdxǝ
#1323 |
#1324 |
Drives: 2013 "AVO Orange" FR-S
Did you install the pipe with the rubber grommet on the bracket? If so, remove the rubber grommet - it allows the pipe to move on the bracket a little, and at the far end (down near the pulley) it can move enough to hit the pulley slightly.
#1325 | |
uosɹǝdʎɐl ʇɹǝdxǝ
i did install the pipe keeping the rubber gormmet in place. I'll remove it and take another cruse with the car as soon as I'm able to...
#1326 | |
There was a spacer that was supposed to go between the bracket and the pipe. But I couldn't see a way to fit the spacer, intake box and the pipe bracket all in there. Is the spacer essential here? |
#1327 |
Are we talking about the spacer that goes inside the rubber grommet?
#1328 | |
Or maybe it is in there in case someone is using an aftermarket intake and can't use the OEM airbox bracket as a spacer? |
#1329 |
That's not meant for that purpose, no. That was probably a spacer for the heat shield.
#1330 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
There is plenty of room for the charge pipe, but you have to put it and the hoses together *perfectly*. You may need to play around with it some to get it in the right place.
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 05:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
