Drives: None
P0018 is keeping me from enjoying my car
At 33k miles p0018 pops up. So far I have reset the battery nothing. I rest the battery and re-flashed my tune, nothing. Replaced the camshaft position sensor A an bank 2, upper left hand side, nothing. I now ordered an ecm from Toyota hoping that it will fix the issue. I do not have warranty anymore because of my avo kit. And to top things off, I crashed my door into my garage. I know there's tons of info on this code already, but damn. It's a very misleading code and extremely difficult to fix.
Also, the last thing I did to the car wars install a clutch, but I know that the Damn clutch is not the issue. I only took off the exhaust and drive shaft while doing so. Sent from my LG-D850 using Tapatalk Last edited by Astroboy; 05-16-2017 at 03:34 PM. |
#2 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#3 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
Drives: Subaru BRZ
Huge E85 fan!
Drives: 2016 Scion FRS
Swapping out parts without properly diagnosing the issue is a piss poor way to fix your car. And expensive. IMHO you need to bring your car to a mechanic and get that diagnosed so you can fix the issue.
You'll run out of money before you run out of guesses. |
Drives: None
#7 | |
Drives: None
Sent from my LG-H820 using Tapatalk |
I Love custom Turbo kits
Drives: Limited BRZ
So how did you fix it?
Drives: Limited BRZ
Another potential fix is to swap cam sprockets?
This is the main reason I am in the middle of an LS swap. I was at a point where, I would need to build the motor for about $10k (from a reputable shop aka FullBlown), plus strengthen/swap the transmission ($4K+) and still have the potential of the sensitive finicky cam gearing/phasing system/ECU fuck up at any time... My FA20 treated me good as it held 500+ whp and 450+ wtq, but even built I would never feel at peace knowing an issue like this could pop up anytime for no reason.
#10 | |
Drives: None
#11 | |
Drives: None
Off topic, but I have huge respect for you because you helped a lot when I was installing my avo kit. You give a lot to this forum Sent from my LG-H820 using Tapatalk |
#12 | |
Drives: Limited BRZ
| CEL P0018 Cams | woode | Issues | Warranty | Recalls / TSB | 69 | 05-13-2023 03:23 PM |
| CEL P0018 | brichard0625 | Issues | Warranty | Recalls / TSB | 8 | 02-10-2016 10:44 PM |
| 31k miles and P0018 happens... | MisterSheep | Issues | Warranty | Recalls / TSB | 65 | 01-18-2016 06:33 PM |
| how are you AT Fr-s enjoying the car =) | mistax | Scion FR-S / Toyota 86 GT86 General Forum | 108 | 06-02-2015 07:29 PM |
| Crawford BRZ Turbo Kit Enjoying E85 | Visconti | Forced Induction | 27 | 04-30-2013 01:16 PM |
