Old 06-28-2012, 02:40 AM   #1
Laurie
Drives: Toyota86, MX5, Jeep, FJ45, 59 Caddy
Exhaust rattle on cold start?
As the title says.. Exhaust rattles on a cold start up and RPMs around 2-3 k... anyone else noticing the same thing?
Will have to get it up on a lift and check all the bolts are tight on the exhaust system... just wondering if this is "normal"
2013 Toyota 86 - 2008 Mazda MX5
2001 Jeep Wrangler - 1982 FJ-45 Land Cruiser Pick-Up
1959 Cadillac Sedan DeVille
Laurie is offline   Reply With Quote
Old 11-25-2020, 11:19 AM   #2
DoubleV
Drives: 2013 Toyota GT86
Hi, did you find anything?
I too have some rattle on cold start that sounds like a cracked manifold.
I have a stock exhaust end-to-end
Thanks!
DoubleV is offline   Reply With Quote
Old 12-03-2020, 01:45 PM   #3
Adinfinitum
Drives: considering buying an 86
had this issue on several cars in the past... typical problem is the heat shield on the catalytic converter will rattle when cold, and get better on warm up. The shields start to fail/rust at some junction. May not be your issue, but have observed it in the past. It only get's worse over time. Other areas to look at are exhaust system joints.
Adinfinitum is offline   Reply With Quote
Old 12-03-2020, 01:54 PM   #4
Impureclient
Drives: 2015 FR-S
This was posted on 06-28-2012
Their last post was on 01-02-2013
Also, you can do a private message by clicking on the persons name.
Impureclient is offline   Reply With Quote
Old 12-03-2020, 03:52 PM   #5
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
how dare you use your brain on the internet
HKz is offline   Reply With Quote
Old 12-04-2020, 12:55 AM   #6
humfrz
Who in the hell made YOU the forum history police?
Old 12-04-2020, 11:50 AM   #7
Impureclient
Drives: 2015 FR-S
You just made my list! No warnings for you, straight to a citation for any infractions you incur.
You better live in the moment and be careful about delving into the past in here from here on out!
Old 12-04-2020, 02:08 PM   #8
humfrz
OK, but, how far do you go back?
Old 12-04-2020, 08:15 PM   #9
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
now we know where hunter is
thomasmryan is offline   Reply With Quote
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 01:56 PM
FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Transmission 28 10-24-2012 01:48 PM
2013 Scion FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Bolt-Ons 2 07-12-2012 08:30 PM
2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review delta86 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-26-2012 04:25 AM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 08:46 PM
