Drives: 2014 Scion FR-S
LTFT reading oft
So this is my first time logging or trying to read the fuel trim readings and what not on the oft.
I know I've got an exhaust leak at the header to overpipe flange and also a small one on the front pipe to midpipe flange What I've been noticing is a constant negative ( - ) reading for my LTFT reading at idle and while moving It flucutates between -3 to -7. It usually sits at -7 at idle or when im not moving. I tried recording today with the oft so I'll try posting a log asap. What does the constant negative reading mean? How bad is the exhaust leak.? The afr readings were a constant 14ish? I have a tomei uel with stock OP+FP with perrin 2.5 cbe EDIT: Here's the datalog I managed to pull. It's kinda all over the place with bad traffic http://datazap.me/u/mike7792/log-145...9?log=0&data=1 Last edited by mike7792; 02-02-2016 at 04:25 AM. |
Fuel trims will fluctuate depending on fuel and temperature. Probably not something to worry about.
It really depends on where your leak is, but in my experience you'll see an idle trim that is wildly different from driving. i.e. a -10% LTFT idle and a 0% LTFT while driving -- and not one that slowly lowers due to heat soak, but one that instantly bottoms out. My theory is that a leak has a fixed volume of air, so as your load increases the overall % affected by the leak becomes smaller. So, if you're seeing a steady -3% to -7%, you're probably doing alright.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
| Where are LTFT data stored? | RustySocket | Software Tuning | 17 | 03-21-2026 12:53 PM |
| Crazy high LTFT, lean codes, e85... | nickw14 | Software Tuning | 18 | 06-23-2015 09:55 PM |
| high ltft at idle, my how to fix it(not fixed yet) | trdric | Software Tuning | 16 | 06-18-2015 11:27 PM |
| LTFT increased over 10% after oil change (new E85 user) | tracerit | Software Tuning | 19 | 05-21-2015 05:35 PM |
| Temperature Swing = Large LTFT Swing? | joneze93tsi | Software Tuning | 5 | 07-31-2014 12:10 AM |
