Old 06-28-2012, 02:51 PM   #1
BR33Z3
BR33Z3's Avatar
Drives: 2013 WRB BRZ
Cusco or KW coilovers?
I'm at a crossroads here, deciding between the Cusco Zero A or the KW v3's. I want the ride to not be much harsher than stock. I will get the car corner balanced/aligned no matter which option I go with. Anyone have any thoughts/opinions and your reasoning? This is my daily driver, i'm not a suspension expert so any insight is appreciated.
BR33Z3 is offline   Reply With Quote
Old 06-28-2012, 03:05 PM   #2
Mitch
form follows function
Drives: RIP '13 BRZ
I'm getting KWs if I ever commit to leaving CS for ST_. No clue on what that's like to live with as a daily driver, but a coworker daily drives them on his AP1.
Mitch is offline   Reply With Quote
Old 06-28-2012, 03:11 PM   #3
solution
solution's Avatar
Drives: Scion FRS
Apparently the KW's don't have camber adjustment ability and will need additional parts that will cost you if you want to do camber adjustment in the front.
I'm currently debating on which coilovers to purchase as well.
solution is offline   Reply With Quote
Old 06-28-2012, 03:20 PM   #4
BR33Z3
BR33Z3's Avatar
I'm ok with buying some camber bolts to get some adjustment for the front. I'm really more concerned with the ride quality. I've had a set of Teins before and they were way too rough for me. I'm leaning towards the Cusco's since they seems to be softer.
Old 06-28-2012, 03:37 PM   #5
jamal
jamal's Avatar
Drives: Legacy GT
I would be VERY surprised if the KWs do not offer camber adjustment. Usually on strut applications where there is no factory adjustment they slot one of the holes. I can't really tell by the picture in scooby south's thread but that appears to be the case.
KWs are going to make for a much better ride and have independent compression and rebound adjustment.
jamal is offline   Reply With Quote
Old 06-28-2012, 03:39 PM   #6
solution
solution's Avatar
Drives: Scion FRS
I think KW's are only 6k which isnt to stiff. Tein Flex are like 7k and Tein Mono are even harder.
Depending on how aggressive you go with rims and rubber you might need a stiffer suspension so you don't rub or bottom out on the road. If your not going too aggressive I hear the KW's have a nice ride/feel. But your right about the Tein it will be a harder ride.
Old 06-28-2012, 03:52 PM   #7
xwd
I would also pick ones which are going to be easily warrantied or serviced if you have a problem. I'd go with the KWs.
Old 06-28-2012, 04:47 PM   #8
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Apparently whoever told you that is clueless. I sell them, hell... I *have* them on my car... I adjusted my camber on the strut.
I do a lot of suspension work, I made one tweak spring rate wise to my KW's and I am extremely happy with them, everyday and when I'm autocrossing too. The ride is firmer, but actually less harsh (better dampers in general and compression adjustment allow some flexibility there too) than the stock struts and shocks.
And independent compression and rebound adjustment is not common. Most link them which is the cheap way out. Add the stainless bodies and lifetime warranty (and that KW is OEM on some pretty high end cars too) and I don't think you can go wrong. I'm very picky about dampers, and I'm very happy that I opted for these. That's more than I can say for some things I've tried in the past on other cars.....
Sam Strano is offline   Reply With Quote
Old 06-28-2012, 05:45 PM   #9
BR33Z3
BR33Z3's Avatar
Thank you everyone for the comments. Definitely helps me make a more informed decision. I'm being extra cautious when it comes to this car. As far as wheels and tires, i'm set on 18" wheels, not sure on tire selection yet.
Old 06-28-2012, 07:01 PM   #10
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Do you mind sharing which spring rates your are running? Thanks.
uspspro is offline   Reply With Quote
Old 06-28-2012, 08:24 PM   #11
Hanakuso
I would go with KW between the 2 but personally I am waiting for Bilstein to come out with there products
Hanakuso is offline   Reply With Quote
Old 06-28-2012, 08:46 PM   #12
jamal
jamal's Avatar
Drives: Legacy GT
I think it's safe to say there will definitely be a Bilstein strut replacement available at some point fairly soon that will be a perfect match for some performance springs that will be available fairly soon.
Old 06-28-2012, 09:10 PM   #13
Coastermikey
Drives: BRZ DGM
Kw's w swift springs is money. I think ast/vorshlag has camber top plates available.
Coastermikey is offline   Reply With Quote
Old 06-28-2012, 09:39 PM   #14
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
You could get white line com c top hats from RCE to add some negative camber and caster up front and fine tune with the lower bolts.
While adjustable top hats are more adjustable I've had very bad experiences with them in the past from multiple brands because of the pillow ball mounts, which can tend to clunk and wear out under street conditions.
You'd need a rear camber solution if you're going to lower your car as well - wpeither the Cusco arms or white line bushings.
Curious to hear about the Strano V3s. When set up well V3s are great but the double adjustability is tricky for the average person to get dialed in and the regular V3springs are a bit soft (6k I believe).
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
>>>> KW Variant 3 Coilovers ~ Now Available for FR-S and BRZ !!!! Circuit Motorsports Brakes, Suspension, Chassis 56 10-25-2012 03:55 PM
D2 coilovers F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2012 04:50 AM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 04:24 PM
Coilovers? trueno86power Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 05-29-2012 06:20 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 09:49 PM
