Old 02-19-2016, 01:06 PM   #1
Seth Hawkins
Seth Hawkins's Avatar
Drives: 2015 BRZ Limited
Question about Valenti Tails
Does anyone know what it would take to get the boomerang light to function as both the tail/running light, and the brake light? I would prefer to not use the strip of red LEDs.
Could this be done? Has anyone done it?
Seth Hawkins is offline   Reply With Quote
Old 02-19-2016, 01:33 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
As it's not dual brightness you'd not be able to get it to work as a brake light when the lights are on.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-19-2016, 03:44 PM   #3
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
It can be done with work.
Open up the tail lights, put a second set of LEDs in there as a running light. The Bar is essentially frosted glass or acrylic over a line of LEDs to defuse the light evenly.
YamahaR86 is offline   Reply With Quote
Old 02-20-2016, 07:51 AM   #4
Seth Hawkins
What about this: Using a rectifier diode and resistor inline with the tail light circuit to reduce the voltage getting to the LEDs, making them slightly dimmer. And using another rectifier diode inline with the brake light circuit. The diodes prevent voltage from 'back feeding' into the other circuit. The output of the brake light diode is connected to the output of the tail light resistor, which is connected to the lights. When the brakes are applied, the lights will get full voltage thru the single diode. Otherwise, the lights get reduced voltage thru the tail light diode and resistor.
Sound doable?
I wonder if someone already makes such a gadget...
Edit: If I use a variable resistor I could vary the intensity of the tail light.
New Valenti tails kamilgt Cosmetic Modification (Interior/Exterior/Lighting) 66 01-18-2016 09:28 AM
VALENTI TAILS OMJM Exterior Parts (Aero, Lighting, Etc.) 0 11-10-2015 05:30 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 07:51 PM
WTB: Smoked Valenti Tails. Smoked Valenti Reverse. Spec-D Headlights. Kephrii Want-To-Buy Requests 0 02-18-2015 02:42 PM
