View Poll Results: Are you interested in billet aluminum seat mounts?
Absolutely. My car needs more racecar parts. 30 96.77%
Nah, I'd like to keep my car as stock as possible. 1 3.23%
Voters: 31. You may not vote on this poll
Old 02-22-2016, 06:46 PM   #1
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Billet Race Seat Mounts
As most of you know, we put a big emphasis on two things: Quality parts, and getting the community involved. We've been detailing our racecar development mule over in the Build Thread section (Link), and now that the cage is done, we're about ready to start installing the "real" racecar stuff. Seats, fire system, master kill switch, things like that.
We designed these seat mounts using a 3D scan of the interior of the car to maximize headroom and allow as many possible mounting configurations as possible.
In this image, you can see them being used to mount our Racetech halo-style seats like we'll be using, but they can accept just about any common race seat mount due to the large quantity of M8x1.25 threaded holes.
They bolt up to the factory seat mounting points using Class 10.9 hardware. You can see the optional sub-strap mount for using a 5 or 6 point harness.
They're being made out of 6061-T6 aluminum with a military-spec black anodizing. Designed and made here in the US. We're hoping to have these in production in the next month or so. Prices are still up in the air, but that's the whole point of this post.
The parts are already designed and sent out for quotes, but the community feedback will help us decide how many we order. Obviously the more we order, the lower the price will be. So what do you say? Are you in for a pair or two?
GSpeed is offline   Reply With Quote
Old 02-22-2016, 07:05 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm not in the market for these, but love your approach to making go-fast parts. If I decide to really get after modifying my car sometime I'll be talking with you guys. Great work.
Old 02-22-2016, 09:34 PM   #3
philooo
Drives: 13' Scion FRS Track car
I actually have 2 race seats in my car, I mounted them using the 'planted seat base' and usual L shape recaro bracket.
It was a pain in the ass, because first the holes on the planted were not ligning up, and were not nearly as far back as I needed them. They would work fine with sliders, but considering the tight headroom with the roll cage I could not afford slider.
Then i have 2 Momo daytona seat, one is the base size, the other is an XL size, which is 1.5" wider. It was a total pain in the ass to try to adjust the side brackets.
Also the 'planted' system has some sort of sub-bar , but it is not located where it should be, it is very forward. So an adjustable sub-bar would also make a big difference.
I am looking forward to a better mounting solution!
Now I want to know , what is the main difference between the G-Speed mount and the VAC one ? I assume you guys purchased a set of VAC to check them out ?
Can you post exact dimensions for your mounts ? something precise so that we can check it if works for us.
I am personally quite interested to buy at least one set, may be two. Depends on pricing
Any early bird specials ?
philooo is offline   Reply With Quote
Old 02-22-2016, 10:28 PM   #4
Knshro13
Drives: 10 series FRS
Im interested. Ive been looking for a fixed seat bracket and looked into Planted, but like above post, I have not heard positive results.
Knshro13 is offline   Reply With Quote
Old 02-22-2016, 10:59 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
I had some VAC mounts in my E30 and loved 'em. Great stuff.
Old 02-23-2016, 12:07 AM   #6
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
We sell the VAC ones for BMWs, but we haven't come across any of their FT86 ones. I can't speculate how ours are different than theirs.
We should be able to post some rough mounting dimensions, but the whole point of the wide variety of mounting holes and slotted mounts is so you can always get something to line up. We know it'll bolt to the floor, and will properly fit to the angled seat mounts (they're not square or planar, so the 3D scanning was worth it).
Old 02-23-2016, 09:53 AM   #7
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I am interested. Looking to start my safety install, cage/seats/harness, over next winter. sub'd
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 02-24-2016, 12:47 PM   #8
TRDGriffon
Drives: 2016 Halo FRS
I'd be interested, looks similar to the macht schnell seat brackets my buddy had in his m3.
TRDGriffon is offline   Reply With Quote
Old 02-24-2016, 01:32 PM   #9
redlined600
redlined600's Avatar
Drives: Fr-s
You might get a better response in the track section.
Old 02-24-2016, 03:32 PM   #10
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Good idea. Just crossposted.
Old 03-04-2016, 04:58 PM   #11
Akuma13
I am interested
Akuma13 is offline   Reply With Quote
Old 03-04-2016, 05:47 PM   #12
-Phil
Drives: Rb25 neo brz
Any update on these? @GSpeed
-Phil is offline   Reply With Quote
Old 03-08-2016, 02:08 PM   #13
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
We haven't had enough interest to justify the manufacturing costs. We wouldn't be able to price them below $300 a pair, and we'd never sell enough. We're going to try the VAC mounts in our car and see how they work, and revisit this design from there.
HOWEVER.
We decided since this design isn't worth pursuing, we're going to be making a low-profile formed steel mount designed to work with the Recaro double-locking sliders.
Here's a peek at the design. These parts have already been ordered, and should show up by the end of the month. They'll be 1/8" cold-rolled steel with black zinc plating. They'll be sold with or without the Recaro sliders included, which bolt up to pressed-in fasteners to make them super easy to install.
We feel this will be useful to many more people than a billet fixed mount.
Old 03-09-2016, 06:18 AM   #14
derek1ee
Drives: BRZ/FRS/STI/M3
Errr... This disappointed to hear... by $300 a pair do you mean for driver and passenger side? asxsxnd does that include anti-sub bar? i'd still be interested if so, if you already made any...
derek1ee is offline   Reply With Quote
FS: Sparco seat bases, rails, and side mounts pleong Interior Parts (Incl. Lighting) 4 03-06-2015 10:41 AM
Adjustable Aftermarket Seat Mounts for OEM Seats RJasonKlein Cosmetic Modification (Interior/Exterior/Lighting) 2 01-31-2015 11:45 AM
Corbeau Seat Mounts at RallySport Direct! RallySport Direct Interior Parts (Incl. Lighting) 8 10-27-2014 04:49 PM
Cobra Suzuka S seat with side mounts. Captain Snooze AUSTRALIA 8 02-27-2013 05:16 PM
Who sells Recaro seat mounts here in the US? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 2 02-05-2013 01:19 PM
