Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
You can use the cheapest oil and your engine will be fine.
Sent in an oil sample to Blackstone and received a favorable report in return.
I've used Mobil 1 0W-20 Advanced Fuel Economy Full Synthetic and OEM filter for all of my oil changes and all is still right in the world. As for use, I've had a couple of track days on this car as well as late nights wringing the engine out in the Santa Cruz Mountains. I've also love practicing my skids which isn't the best on the engine... or the axles... or the rear tires... but lo, readith from the book of Blackstone and believe.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
Drives: Nevermorange FRS
The Mobil One AFE 0w-20 is actually a pretty good oil.
PRO86 | STL | LuckyDog
Drives: 2005 Toyota Camry
No one said cheap oil was inferior.
As long as it meets minimum specs for the car as specified by the manufacturer, any oil will do. -alex |
Drives: Full race 4cyl boxer
And FYI the manufacturer has attributed at least some of the cam phasing engine problems and engine failures on properties of the oil.
For a few extra $$ I like using exactly what the dealer tells me to use so there are no "outs" for them to use later. |
[insert cool phrase here]
Drives: BRZ Premium
By cheap do my mean the Walmart brand oil?
Cause Mobil 1 is not a "cheap" brand. Although you can buy it hella cheap at Walmart
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Boost Creep
Drives: 2016 HyperBlue BRZ
This isn't a shitty or cheap oil, I don't really know what you're on about. If cheap were a measure of quality, half the Subaru gang wouldn't be running Rotella T6.
Just drive it
Drives: 13' FR-S
I thought you meant this by cheap oil.
Drives: car
I spend maybe $10 bucks more buying Castrol Edge 0w-20 at Walmart. It's a drop in the bucket as far as I'm concerned to use my preferred brand.
Drives: '13 SWP ZC6 R
Cheap may not be the right description for Mobil1 but many, many posts have been made on this (and other) forums warning against its use in boxer engines.
Thread title should be updated to "STFU: Mobil1 is fine"
#10 |
Drives: frs
Cheap can be subjective
#11 |
Drives: '14 Midnight Purple FR-S
I wouldn't exactly call Mobil 1 the cheapest oil...
#12 |
Mentat
Drives: 2013 Scion FRS 6MT
Toyota 0w20 is half of the price compared to any other 0w20.
| 94 Octane rom fine tuning for OFT | FT86Z | Software Tuning | 12 | 01-09-2016 10:15 AM |
| CARB Fine California | Phantobe | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 11-23-2014 12:50 AM |
| Something fine... | Porsche | BRZ First-Gen (2012+) — General Topics | 3 | 12-16-2013 02:45 AM |
| Something fine... | Porsche | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 12-13-2013 11:29 AM |
| Something fine... | Porsche | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 12-13-2013 11:14 AM |
