Old 03-24-2016, 12:10 AM   #1
apelpapa
apelpapa's Avatar
Drives: 2013 SPD Black FR-S
PCV Valve Replacement with STI Valve
I just installed the SPD kit on my car and I picked up a STI PCV Valve since a lot of people were recommending replacing it since the stock one is plastic. However where I would assume the PCV Valve is installed is right behind the intake manifold where the passenger side hose is going to from the intake manifold, right? Mine is metal (maybe the inside piece is plastic?)
So my question is am I looking at the right thing to replace? If so did you just use a socket with an angler to replace it, because it is kind of a pain where it sits right now?
I'm sorry if this isn't in the right section. I figured it would be with forced induction.
I've tried to google it but all I come up with is replacing the small plastic elbow, but that was hollow and replace with a straight metal tube during installation.
apelpapa is offline   Reply With Quote
Old 03-24-2016, 12:13 AM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Delete it and install a catchcan.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-24-2016, 12:14 AM   #3
apelpapa
apelpapa's Avatar
I'm planing on installing a catch can in the summer, just holding off a little to recoup a little bit of funds
Old 03-24-2016, 09:31 PM   #4
GsxrMe
GsxrMe's Avatar
I know how you feel but catch can and oilcooler is a must. The engine will take a beating even if it's a 7psi basemap tune with DD car.
I had oil leaks from anywhere the damn pressure could get out during WOT. Pcv delete, catchcan fixed it real fast.
2014 Subaru BRZ
Old 03-24-2016, 09:36 PM   #5
Bykov
Drives: 2014 Monogram FR-S Whiteout
The JRSC instruction manual has instructions for installing it. That would be a good place to start. It has specific placement. I would go into why placement is important but I don't feel like looking through the KWSC thread for where it's mentioned. Hope that helps.
Bykov is offline   Reply With Quote
Old 03-25-2016, 12:01 AM   #6
apelpapa
apelpapa's Avatar
Thanks for that, they installed a one way check one the hose I was thinking about, so I'll just swap the valve at the end of it. Thank you!
Old 03-25-2016, 12:03 AM   #7
apelpapa
apelpapa's Avatar
Ya, I'll probably order the dual radiums next week and just install the valve in the middle of the line temporarily until they come in
Old 03-25-2016, 01:04 AM   #8
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
You don't replace the stock one because it is plastic, you replace it because it was never meant to see boost, so it opens up(under even 1psi from my testing) and lets boost into the crank case (bad)
A 19mm deep socket and a medium extension will get the old one out (it will be tight, but comes out) Screw the new STI one in by hand and then tighten down with the socket/ratchet.
The Racers Line is offline   Reply With Quote
Old 03-25-2016, 04:15 AM   #9
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Yea idk who said the stock PCV is plastic; it is very much metal. I put in the one from the FA20F WRX.
Any reason they say to use the STI one? Is it better? Didn't even realize those were compatible.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 03-25-2016, 09:53 AM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Shouldn't be much difference. WRX/STI, both were made to see boost, so they both work for the application.
Old 03-25-2016, 03:48 PM   #11
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
its definitely metal. i drilled out the check valve in mine so it was wide open for my atmospheric vent catch can.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-25-2016, 07:31 PM   #12
GsxrMe
GsxrMe's Avatar
BINGO
Yep. Blow by creates presure in the case. If the valve is shut over boost then the crankcase can't let the presure out. The front case vent isn't enough.
Put a cap plug on your intake plenum and vent to atmosphere. a filter popped on the barb is better than back presure. And BOOM!
When I boosted my Busa, I left my crackcase vent wide open. Not worth it not to.
2014 Subaru BRZ
Old 03-26-2016, 01:36 AM   #13
apelpapa
apelpapa's Avatar
Ya, I'm not sure were I heard that it was plastic. Thanks for the replies guys.
Old 03-26-2016, 10:15 PM   #14
mrk1
Drives: Sterling BRZ Ltd
I run a VTA can and just replaced the valve with a hose fitting of the correct threads, boom done.
I did it just for simplicity, one less thing to fail.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
FS: Fumoto Valve jvenetto Engine, Exhaust, Bolt-Ons 6 10-01-2015 08:16 AM
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 07:38 PM
Heart valve replacement surgery mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 94 09-17-2014 02:45 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 02:47 AM
