Old 04-01-2016, 02:28 PM   #1
S84kam
S84kam's Avatar
Drives: FBRZS
BRZ headlight shroud inside FRS headlight?
Can someone tell me if this will fit inside the FRS's headlights? As in, opening up my FRS and just throwing these bad boys in? I'm very interested in doing a boomerang mod to my FRS
S84kam is offline   Reply With Quote
Old 04-01-2016, 03:53 PM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
They lights are interchangeable so don't see y not
lbroskee is offline   Reply With Quote
Old 04-01-2016, 03:59 PM   #3
S84kam
S84kam's Avatar
Drives: FBRZS
Im going to add another question... but first, theres plenty of broken Ebay BRZ headlights (mainly the front clear plastic piece) Would i be able to use my FRS's front clear plastic piece and throw it over a broken BRZ?
Old 04-01-2016, 04:44 PM   #4
8R6
8R6's Avatar
Drives: FRS
probably not. the frs headlights are a tiny bit longer than the brz (at the pointy part towards center of car).
8R6 is offline   Reply With Quote
Old 04-01-2016, 05:36 PM   #5
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
OP, if no one else knows for sure, please be the first to take the plunge and attempt this for the benefit of our community...and make sure you document it well with a DIY. thank you in advance.
shiumai is offline   Reply With Quote
Old 04-01-2016, 05:37 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
My $0.02 is on this not going very well.
Old 04-01-2016, 05:40 PM   #7
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
The FR-S headlight is not really longer at the center than the BRZ one.
From Perrin
The BRZ light is missing that “sharp” corner where the headlight meets the bumper, or is it….. In the picture below, you can see with the bumper removed that there is a plastic piece covering up this corner. Removing this small piece makes both the FR-S and BRZ headlight the exact same shape! This also means, customers can do some swapping out of headlights!
mrderp is offline   Reply With Quote
Old 04-01-2016, 07:18 PM   #8
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Wouldn't it be easier to just swap BRZ headlights....the full assembly?
Old 04-01-2016, 07:43 PM   #9
8R6
8R6's Avatar
Drives: FRS
From Perrin
well damn. i didnt know it was just a plastic "cover" over the housing. the more you know
Old 04-02-2016, 01:24 AM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It's the same reason why winjets etc. Fit both cars
Headlight help Hotrodheart Scion FR-S / Toyota 86 GT86 General Forum 13 09-26-2015 11:35 PM
Headlight haze on the inside? Sexyeve Cosmetic Modification (Interior/Exterior/Lighting) 4 04-18-2015 01:19 AM
FS: OEM FRS Headlight & HID kit ravisingh011 Exterior Parts (Aero, Lighting, Etc.) 1 09-17-2014 02:46 PM
LED Headlight Kit Gps360 Cosmetic Modification (Interior/Exterior/Lighting) 14 02-06-2014 06:20 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
