Old 04-06-2016, 01:29 PM   #1
Wired86
Wired86's Avatar
Drives: 2016 Subaru BRZ, Limited, MT, CBS
Preferred downshifting method?
I was just pushing the clutch in putting it into the lower gear and then pressing the gas pedal liberally while releasing the clutch. I have now started practicing heel toe. Blipping the throttle with it in neutral and foot slightly on brakes then throwing it into the lower gear and then gas in and clutch out.
Is there a method that I should be doing? Or does it not really matter?
Still have tons to learn with manual, so don't make fun of me too much. :P
Originally Posted by softgrip View Post
Last night I took a corner that would have given me a 4 wheel power slide in the WRX. The BRZ hunkered down and massacred the corner with no loss of traction or speed.
Wired86 is offline   Reply With Quote
Old 04-06-2016, 01:33 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Put it in a lower gear when/if needed. Pretty much don't need to be rev matching, blipshifting, double clutching, heel-toeing etc when driving normally.
Old 04-06-2016, 01:35 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I rev match downshifts and double clutch rev match if skipping gears.
DOn't know what is correct just how i do it.
Old 04-06-2016, 01:36 PM   #4
Kerune
Kerune's Avatar
Drives: Lexus RC-F
You don't need to heel toe unless you really need to slow down and expecting to accelerate right away, i.e. making a turn but you went from 40 to 20mph you can heel toe to get you down to the right speed and be in the right gear right away. Even then you're mainly doing it for the sake of no jerking and being at a preferred rpm.
Otherwise what you're doing is right, still practice the heel toe for the sake of learning it but you're essentially just rev matching regardless if you're braking or not. Just clutch in, blip the throttle while switching gears and release clutch at a smooth rpm.
Kerune is offline   Reply With Quote
Old 04-06-2016, 01:37 PM   #5
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
hell toeing/ blip shifting, etc. is normally not needed for everyday driving.. You should rev match for smoother downshifts but that's about it when it comes to daily driving..
Instagram: trevor.parque
Old 04-06-2016, 01:40 PM   #6
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
i rev match when wanting to take a turn faster or when i want to pass someone
Atticus808 is offline   Reply With Quote
Old 04-06-2016, 02:33 PM   #7
Wired86
Wired86's Avatar
Rev matching is essentially what I said that I've been doing right? Just clutch, neutral, lower gear, gas to right rpm as I pull the clutch out. Is that right for normal driving? It feels right. When I do it to the proper rpm, there isn't any jerking or excessive acceleration.
Old 04-06-2016, 02:36 PM   #8
Wired86
Wired86's Avatar
Also when in 3rd or 4th gear and rolling up to a stop light, I clutch and brake, neutral, clutch out, come to stop, clutch in, put it in first and wait. Is that proper for minimal clutch wear? Or should I just hold the clutch in all the way through the deceleration to the stop?
Old 04-06-2016, 02:42 PM   #9
MisterSheep
Killed Scion
I would go to 3rd gear and when u start to get below 1500 rpms follow this sequence;
Clutch in
3rd to neutral
Clutch out
coast to stop
wait at light til green
clutch in
first gear
go.
Never just hold the clutch in when not needed. That puts premature wear on your throw out bearing and out cars are notorious for having bad TOB..
Old 04-06-2016, 02:51 PM   #10
Over thinking the whole thing once again! If it feels right do it. If not don't.
Old 04-06-2016, 02:52 PM   #11
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I prefer the paddle on the steering wheel for downshifting
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 04-06-2016, 02:55 PM   #12
coloradobrz
coloradobrz's Avatar
Drives: 15' CWP Limited
I just rev match every downshift out of habit and it's smoother. For agreesive-ish daily driving I only heel and toe when going from 40+mph to a right hand turn. Otherwise just don't ride your clutch and drive it like a normal manual car.
coloradobrz is offline   Reply With Quote
Old 04-06-2016, 03:00 PM   #13
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
You should really learn and master how to do them all (rev-match, double-clutch, heel and toe, even granny) as you can use any one of these techniques in different situations of traffic at various speeds.
Don't overthink just keep practicing and most importantly get some good fitting shoes with thin flexible soles (I always recommend Onitsuka Tiger Mexico 66 which is readily available).
Thin soles give you good pedal feel so you can accurately apply the amount of gas / brake / clutch. The best I've found is actually Geox Xense Moc but I've had durability issues with them from too much walking (burned thru 3 pairs in 2 years and not exactly cheap either).
krayzie is offline   Reply With Quote
Old 04-06-2016, 03:06 PM   #14
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
You should never be sitting at a light holding the clutch in; you will prematurely wear out the throw-out bearing.
GeorgeJFrick is offline   Reply With Quote
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 07:59 AM
[Poll] Preferred method to start stop on hills Koa Scion FR-S / Toyota 86 GT86 General Forum 62 02-20-2015 05:34 PM
1-Bucket Method (Gary Dean) - The best rinseless wash method Obsidiank Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 09-23-2013 02:00 PM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 10:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 02:20 PM
