Old 07-02-2012, 07:54 PM   #1
nubbster927
Drives: BRZ Limited 6MT
Optimistic fuel economy?
Does anyone else have have a wildly optimistic avg. fuel economy reading on their trip computer? For my last two tanks I had an average reading of 37.8 and 36.5 mpg when I filled up (I reset it every time I fill up) but when I calculated it myself both tanks came to ~31-32 mpg. I still only have 900 miles on mine so I've been driving pretty easy. Maybe it'll get more accurate after the break-in period. And it's a manual tranny if anyone's wondering. I can't complain because these are still great numbers, but does anyone else have inaccurate readings?
nubbster927 is offline   Reply With Quote
Old 07-02-2012, 07:55 PM   #2
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Mine has been consistently +2 mpg
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 07-02-2012, 07:55 PM   #3
engee
Drives: Subaru
All new cars with the comuter calculation always overestimate. This is probably due to rounding. For accurate numbers, calculating itself is your best bet.
engee is offline   Reply With Quote
Old 07-02-2012, 08:53 PM   #4
cwik
cwik's Avatar
Drives: 1st NA BRZ, 2007 GSX-R 600
I've noticed this to a certain degree. It seems like the average reported by the car is usually between 0 and 1.5 MPG extra. I'm curious if they ignore idling or cheat in other ways :P.
On the flip side, trying to report instantaneous and average MPG without random spikes *and* being spot on would be difficult to implement.
As engee mentioned, calculate it yourself. I just signed up at fuelly and it's really easy to use. I'd recommend it so long as you don't mind giving up data on your fuelling habits.
cwik is offline   Reply With Quote
Old 07-02-2012, 09:35 PM   #5
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
In my first tank of gas the trip computer was fairly accurate with < 1 MPG overestimate. For my second tank of gas the the trip computer overestimated by about 3 MPG. I had a lot more idling during my second tank because I spent quite a bit of time sitting around trying to get the GPS to work. So, maybe the trip computer is ignoring some of the idling time in its average MPG measurement.
DSPographer is offline   Reply With Quote
Old 07-02-2012, 11:12 PM   #6
DeepHunta
Drives: '05 Outback Wgn, '05 Lotus Elise
depends on your mode of commute. I mainly do city driving so my avg is 25 mpg total. I have some freeway driving too hence the "higher" avg than the city estimate of 22mpg.
I'm also around 900 miles odo.
Proud ex-owner of GBS 6MT BRZ Limited. Pre-ordered on Feb-29-2012, got VIN on 5/19 with ETA 6/6, arrived early on 6/2, but still didn't pick it up until Jun-6-2012. Recently sold the Buuurz as of 4/21/2014
DeepHunta is offline   Reply With Quote
Old 07-02-2012, 11:20 PM   #7
immortal_suby
Drives: 2015 BRZ Limited 6MT
I've noticed on the wife's outback that if I hammer on it to get up to speed and then coast vs. a more conservative ramp up to speed it tricks the computer into showing a better average mpg.
Also - there is a program mode to adjust the mpg readout for the outback - to correct it being off - I imagine the procedure will be similar for the BRZ.
immortal_suby is offline   Reply With Quote
Old 07-03-2012, 02:12 PM   #8
Lytheum
Drives: 2013 BRZ Premium 6MT
mine has been spot on so far. just did my 3rd fill up and i calculated 29.5. then checked the computer and it also showed 29.5.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 07-03-2012, 02:28 PM   #9
billysangi
3 fill ups......avg 34 mpg per tank
billysangi is offline   Reply With Quote
Old 07-03-2012, 02:54 PM   #10
Double4Free
Ashes to ashes.
Double4Free's Avatar
Drives: Asphalt FR-S
I do nearly all city, and im averaging about 24-25.
Double4Free is offline   Reply With Quote
Old 07-03-2012, 04:39 PM   #11
DeeezNuuuts83
Drives: 2006 Evo IX SE
That's probably what it is then, since most cars with mpg displays usually go blank when you're idling at a complete stop, so it's not averaging moments of 0 mpg.
DeeezNuuuts83 is offline   Reply With Quote
Old 07-03-2012, 06:09 PM   #12
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Mine said I would get 26.6 last tank and I got 30.5 but...I hadn't reset the Ave MPG since I bought the car so thats why. Not helpful I know but I was still pretty happy to see over 30mpg during engine break in (about 800 miles atm).
slizoth is offline   Reply With Quote
Old 07-03-2012, 06:53 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Last fill up said average = 28.8, actual by the math 28.7. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-05-2012, 08:32 PM   #14
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
The MPG on the trip computer is the average mileage you got since the car was first driven, unlike other Subaru's it's not tied to trip A or B that will reset when you clear your trip. You may have gotten 37MPG since you've had the car, but the last fill-up was under the average for the car.
With me, my average is 0.8MPG higher on the display than it actually is.
EDIT: Unless there is a way to manually reset the average MPG?
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
fuel economy
Canadian fuel economy different rating Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 14 10-04-2012 09:16 AM
94 AKI vs. 91 AKI Fuel smbrm Scion FR-S / Toyota 86 GT86 General Forum 14 05-28-2012 07:45 PM
Subaru shows courage to cut horsepower for fuel economy [es vi: eks] Engine, Exhaust, Transmission 11 05-01-2011 03:02 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 04:50 PM
E85 Fuel? Siriusly.Andrew Scion FR-S / Toyota 86 GT86 General Forum 60 02-11-2010 06:00 PM
