Old 05-03-2016, 01:54 AM   #1
Vic91
Vic91's Avatar
Drives: 2015 Scion FRS RS 1.0
P0031
So I just installed my tomei UEL headers,over pipe and tanabe front pipe. after the installation the CEL came out right away so I decided to buy the OFT to tune my car and to get rid of the CEL. Now my problem is the CEL is still there after tuning it with the stage 2 UEL 93oct. the code is P0031. How will I get rid of the CEL?Help please.
Vic91 is offline   Reply With Quote
Old 05-03-2016, 02:23 AM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You installed some hardware which resulted in a hardware fault, which you decided to solve with software.
Go fix and/or replace your oxygen sensor which you damaged or plugged in reverse (dunno how that would even be possible).
Old 05-03-2016, 06:26 AM   #3
steve99
google this "P0031 subaru"
as above its likely stuffed front 02 sensor
the code you get with catless header is P0420 cat efficiency this is disabled in oft stage2 tunes.
the tune is fine your have an o2 sensor issue to fix
read the Basic Bolt on Mods guide link below in pretty colours its got some tips in it to reduce your chances of stuffing the next sensor, ie run a thread tap through o2 sensor bungs in header so you dont need to force them in.
you might have also blown the "efi htr" fuse see here if the wiring is damaged or the o2 heater went short circuit
http://www.ft86club.com/forums/showt...92#post2205392
Old 05-03-2016, 12:52 PM   #4
Vic91
Vic91's Avatar
thanks mate! i'll check it now and hope I can fix it
Old 02-09-2018, 01:56 AM   #5
niceman
Drives: 2017 GT86
how did you red of CEL in the end ? thanks
niceman is offline   Reply With Quote
Old 11-18-2022, 11:44 PM   #6
stainyrand
Drives: brz '16, elise s3 '15, mb c250 '14
How did u fixed it?
Got the same, UEL was installed by a garage.
stainyrand is offline   Reply With Quote
Old 11-18-2022, 11:54 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by stainyrand View Post
How did u fixed it?
did you follow the steps in post #3?
cel, headers, o2 sensor, oft.vishnu.tune.tunning
P0134 and P0030->P0031 Howardwei Software Tuning 7 12-08-2013 03:39 PM
