Old 07-03-2012, 12:33 PM   #1
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
any way to reduce or eliminate "idle creep"?
I've had little experience with automatic transmissions. Most of my cars have been manuals. I went with the AT FR-S and I like it, but I find the "idle creep" to be a little excessive. Is there any free or relatively inexpensive way to reduce or eliminate this effect?
Thanks!
Nepenthe is offline   Reply With Quote
Old 07-03-2012, 12:46 PM   #2
TuxedoCartman
Drives: '13 86
Thanks!
Judicious and appropriate application of the brake pedal.
TuxedoCartman is offline   Reply With Quote
Old 07-03-2012, 12:54 PM   #3
Nepenthe
Thanks. I've actually tried that.
It works, but only as long as the foot is firmly planted into the brake pedal. Let up and the car is lunging forward again.
Anything more... permanent?
Old 07-03-2012, 12:56 PM   #4
TuxedoCartman
Drives: '13 86
Probably not. Every automatic car I've owned does that.
Old 07-03-2012, 01:13 PM   #5
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
yup.. that's normal for automatic cars. the torque converters in the transmissions are constantly transferring torque to the wheels, even at a full stop. you just gotta hold the brake pedal down, or shift to neutral (& e-brake if you're on an incline).
azian_advanced is offline   Reply With Quote
Old 07-03-2012, 01:17 PM   #6
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
This is actually funny to me since I mainly drive auto's. I was wondering what the hell you meant until I read the other posters post.
SUB-FT86 is offline   Reply With Quote
Old 07-03-2012, 01:19 PM   #7
2pt5RS
Berz
put it in neutral.
2pt5RS is offline   Reply With Quote
Old 07-03-2012, 01:26 PM   #8
Nepenthe
I remember, for instance, the literature for the 2001 automatic Vette boasted that some new pulley lowered idle speed and reduced or eliminated idle creep.
http://www.cardomain.com/ride/430621...rolet-corvette
^that's available in a number of different spots on the web. Here:
The alternator has a new clutch pulley that allows a reduction of engine idle speed on automatic-equipped Corvettes. This seemingly-small quality upgrade makes the car smoother and quieter in city driving, reduces or eliminates "idle creep" at stoplights and helps enable the improved fuel economy ratings already mentioned.
I think the most annoying part is the awkward tap dancing you have to do on the brake pedal when you're moving slowly in a long four-way stop line, for instance. It's also a little annoying to have to keep the pedal down at a long light. The grunching noise it makes at the transition between just enough pedal pressure to stop it and when it starts moving is irritating.
Just wasn't sure if there was a recognized adjustment. Seems not. Oh well.
Old 07-03-2012, 03:00 PM   #9
phattyduck
Drives: '03 WRX Wagon, '89 Camry Alltrac
Reason #1087 to buy a manual transmission car?
-Charlie
phattyduck is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 01:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 03:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
