Drives: Black 2013 FR-S
Offset on rpf1 for a lowered car
I am going to be buying a set of rpf1s in 17x9 for my car, and was wondering what offset I should buy, +35 or 45. I would like to be able to avoid spacers so I was thinking the +35, but I want to be sure I won't get rubbing with the 35 because it has been lowered on swift springs an inch. It's running 1.5 degrees camber in the front and 2.5 in the rear. I would think with the camber I would be fine, but I want to be sure. If I get +35, I was also wondering if I would need my fenders rolled. Thanks in advance! Share any picks of a similar set up if you have them please
Drives: LR BRZ Limited
when in doubt, always go lower offset.
Off Topic
This thread will tell you all you need to know. http://www.ft86club.com/forums/showthread.php?t=7535
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
depends how low you're going. +45 will tuck, but at full lock you'll probably rub. +35 will poke if not low enough. if low enough, will be cambered atleast 3 deg in the front. rears will fit with like -2--3
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
Our cars rarely need the fenders rolled. With the setups you're considering, you will not need the fenders rolled.
#6 | |
Drives: 14 Ultramarine FR-S
-2.2 rear http://www.ft86club.com/forums/showp...&postcount=634 Very slight poke up front
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
Drives: 2013 White-Out FRS
Instagram - BattleBunny86
I'm lowered on RSR Superdowns (1.4ish) springs with 17x9 +35 RPF1s and a pretty meaty 245/40/17 tire setup. No rubbing at all. Camber is -1.5 in front (SPC camber bolts) and -3.0 in back (natural).
I live my life one quarter-pounder at a time.
#8 | |
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
| Tags |
| enkei, fit, offset, rpf1, wheels |
| WTB: 2 enkei rpf1 16x7 offset +35 | LFA.Baby | Want-To-Buy Requests | 0 | 09-18-2015 12:50 PM |
| Enkei rpf1. 17x9+35 offset | Geeteepee | Southern California | 4 | 01-27-2015 08:12 PM |
| Best offset for RPF1 (+35 or +45) in 17x9 and track/AX use | dp1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-19-2014 05:01 PM |
| Lowered 1" and have a 265/35 or 255/35 tire +38 offset please post pics! | ScionFR-S | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-30-2014 03:26 PM |
| FS: Socal rpf1 black 17x9 45 offset | toby714 | Wheels and Tires | 13 | 08-19-2013 12:17 AM |
