Drives: none
Is there a Subaru TSB for the direct injector seals?
I've searched extensively but cannot find a Subaru TSB for the detonation issue at throttle tip-in that causes injector seal failure. Does such a thing exist? I've seen the Toyota TSB from South Africa that's floating around but somehow I doubt my local Subaru dealer will care about that one bit
I'm having the detonation problem on my 2013 BRZ and am planning to take it in to the dealership this week so I would like to be prepared.Thanks! -Matt |
#2 | |
http://www.ft86club.com/forums/showthread.php?t=21868
#3 | |
Drives: none
edit: Ugh.. apparently I can't link to another forum... This thread discusses the problem in detail and the youtube video linked there shows the toyota of south africa TSB at the beginning. http://www.ft86club.com/forums/showt...ica+detonation -Matt |
#4 | |
If you are talking just the ECU flash then there may be no TSB for it but the dealer shouldn't put up any fight in just giving you the latest version.
Drives: none
Yeah, I'm not worried about getting the flash.. I'm worried about getting them to inspect (and replace, if needed) the injector seals. Just getting to them to check if they're damaged is a pain. The fact that I get an occasional backfire and consistent detonation would indicate to me that the seals are damaged. I just need to convince the dealership of that as well.
-Matt |
#6 | |
| do the direct injector seals need to be replaced? | Astroboy | Engine, Exhaust, Transmission | 17 | 04-15-2015 07:01 AM |
| Injector Seals went Bad while tuning my car | whitefrs | Forced Induction | 128 | 08-20-2013 01:19 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 10:31 AM |
