Drives: Toyota 86
Diff and gear oil. Fill to overflow, or service manual capacity??
I am going to be changing my diff and gear oils again with lighter weight oil.
Last time i did them, i filled until the fill hole dribbled. BUT I fit a lot more in than the service manual recommends. So what is the go here? I dont want to have too much oil in there sapping power from my 86 series race car.. I have always filled to the fill hole before. manual states 2.2 for GB and 1.1-1.2 for diff. I fit appx 2.8-3l in GB and 1.5-1.6 in the diff |
Oh, I'd suggest you just fill them up till they won't take any more and call it good.
humfrz |
Drives: 2005 Toyota Camry
Both are fine. If you want every ounce of performance, fill it to capacity as specified
-alex |
Drives: Toyota 86
not playing cards
Verify they are level along both pitch and roll axes, fill until overflow, wait a bit, top them off to make sure. Don't overfill.
Off Topic
Drives: Toyota 86
not playing cards
Fucking peanut gallery... As soon as I submitted I knew I was gonna regret it.
#10 |
not playing cards
#11 |
Drives: 15 BRZ LTD, 05 FXT
Fill until it comes out, then have a beer, then put the plug back in with a fresh crush washer.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#12 |
Drives: SWP BRZ
I just try to fill close to capacity indicated in shop manual.
#13 |
Drives: '16 FRS-MT Ablaze Red
I just finished a clutch install, and I filled the transmission gear box until the oil started to seep back out the fill hole. I measured the oil remaining in the last bottle. Based on what’s left, I filled to about 2.6 liters. Will I have any issues with the extra fluid being in there or should I drain it and refill to 2.2L? Thanks
| Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 09:02 AM |
| Limited Slip diff oil Motul GEAR 300 LS 75W-90 | FRSToyota86 | Canada Classifieds | 12 | 08-22-2014 01:47 PM |
| Tri-State Locals Special on NEWLY RELEASED Greddy HIGH CAPACITY DIFF COVER !!! | 468Power | NY / NJ / CT / PA | 5 | 10-24-2013 11:21 AM |
| Rear diff service | JoeBoxer | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 11-06-2012 11:23 PM |
