Old 06-29-2016, 11:30 PM   #1
LenA
Drives: 2015 Silver BRZ
Bushings for DD
I've read a lot about bushing replacements to improve shifting and handling. I am most interested in rear shifter bushing, the Whiteline positive shift and maybe Whiteline rear subframe.
Will any of these really have any noticable effect on street or are they really only noticable on track or at 9 tenths on street, which is rarely achievable.
I DD my BRZ in LA, so can't do much about torque dip legally outside of FI, so improving feel and responsiveness throught weight reduction and bushings etc are only good options.
Thanks
Len
LenA is offline   Reply With Quote
Old 06-29-2016, 11:37 PM   #2
BRZHarley
Drives: 69 Firebird, 2015 BRZ
Len
I think the Whiteline were the first bushings I change in my and what difference!
I personally don't see a need for tranny/shift bushing, the next ones I would consider the front sway bar bushings.
Good luck , Ed
BRZHarley is offline   Reply With Quote
Old 06-30-2016, 12:04 AM   #3
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
The rear subframe bushing is very subtle and causes some understeer; The differential insert bushing is simply mandatory, makes the car smoother and therefore faster.
I did the Perrin transmission mount insert (similar to Whiteline Positive Shift) and it makes the car easier to shift, and a bit noisier. Worth it.
The rear shifter bushing does one thing, and one thing only: Makes the gears grind worse.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 06-30-2016, 12:06 AM   #4
LenA
Which Whitelines did you install other than rear subframe and sways?
Old 06-30-2016, 12:24 AM   #5
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Bushings for DD
Get STI everything.... You won't get better DD setup then that. LA road isn't really hardcore bushing friendly
http://www.ft86club.com/forums/showthread.php?t=84332
Its gonna cost more but STI bushings/group N bushing on everything will net you the best result for DD.
Improves everything & just moderate amount of nvh cuz oem.
Old 06-30-2016, 12:51 AM   #6
ryoma
ryoma's Avatar
a lot of people say that the rear diff bushing inserts caused the most NVH but it doesn't bother me. I even have Cusco engine mounts and at first, they seemed harsh, but I barely notice it now. my BRZ is my DD and I have all of the drivetrain bushings/inserts (engine mount, transmission bushing, shifter bushing, rear diff inserts, and rear subframe inserts).
though if you want improved shifter feel, I highly recommend a short shifter, transmission bushing, shifter bushing, and MTEC springs. you will hear the whine of the transmission though, but I actually like that sound (sounds a lot like a supercharger lol). short shifter and the MTEC springs will give you a dramatically increased shifting feel while the bushings just add on to that but will increase NVH. I didn't buy the BRZ to be a luxury or comfort car so I could care less if there is more NVH
Old 06-30-2016, 01:54 AM   #7
choiboie
Drives: 2013 Fr-S UltraMarine
Im going to finish up on the bushings and add some braces as well. I bet your ride drives very nice
Sent from my SM-G920V using Tapatalk
choiboie is offline   Reply With Quote
Old 06-30-2016, 02:03 AM   #8
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Rear shifter bushing - Do it, get the Kartboy one. Works well, no NVH and shiffens up the shifter throws nicely.
Transmission "Insert" Bushing - DON'T do it, I ran one for over a year and the stock trans mount actually failed. Buy the STI BRZ Trans mount instead! Accomplishes the same thing with ZERO NVH and far more reliability.
Rear Subframe bushing - These add a little NVH as first but you stop noticing it within a week. Rear end is slightly more responsive, but these are cheap and easy to install so might as well.
Rear Diff bushing - DON'T do this if you care about NVH! I had these in for one week and couldn't stand it, had to remove them immediately. Causes a lot of harsh vibrations from the rear of the car, even felt like the diff would get out of position at times and cause some strange feelings in the car... This is something I would save for a serious track day car.
Kostamojen is offline   Reply With Quote
Old 06-30-2016, 03:27 AM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Rear upper control arm bushings have the biggest impact imo. Huge improvement in the rear of the car being planted. But they also have made the ride much harsher if that matters to you.
Old 07-02-2016, 08:29 PM   #10
LenA
Thanks all for suggestions/feedback.
Len
Poly bushings wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 09-14-2015 06:49 PM
Bushings - which to buy? Flasher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-18-2014 02:14 AM
FS: (RI) WL Bushings enjoyminutemaid Engine, Exhaust, Bolt-Ons 8 09-27-2014 08:46 PM
Sale on Bushings.. HORSEPOWER DIRECT Brakes, Suspension, Chassis 0 01-03-2014 10:12 PM
STX bushings? -max- Tracking / Autocross / HPDE / Drifting 2 10-07-2012 03:42 PM
