Old 07-06-2012, 12:51 AM   #1
wallace03
wallace03's Avatar
Drives: WRB BRZ
alcantara maintenance.
has anyone safely applied 303 fabric gaurd or any other form of protectant on their alcantara seats? i heard its not suppose to get wet, but the spray is liquid.
wallace03 is offline   Reply With Quote
Old 07-06-2012, 05:48 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Anyone on the alcantara care?
Old 07-06-2012, 09:23 AM   #3
bryansbestwax
Drives: black suv
I have cleaned with raceglaze alcantara cleaner and protected with cg fabric guard before. No issues.
Sent from my Galaxy Nexus using Tapatalk 2
bryansbestwax is offline   Reply With Quote
Old 07-06-2012, 11:09 AM   #4
2pt5RS
Berz
Maintenance- in order to preserve your upholstery, vigorous cleaning of accumulated dirt should be avoided as dirt / grit is abrasive and may damage the finish.
It is therefore recommended that regular cleaning is carried out by brushing seating areas with a soft upholstery brush and then vacuuming to remove dust and loose dirt. Avoid rubbing too strongly. The use of steam machines is not recommended, although the use of dry-vapour steam is recommended
taken from This link, however, their website is REALLLLLLY slow right now.
2pt5RS is offline   Reply With Quote
Old 07-06-2012, 11:14 AM   #5
brianc
OCD
brianc's Avatar
People recommend a woolite to water mixture to clean alcantra. I don't spray anything on my alcantra seats to protect them. They are still one of the cleanest sets of recaros I've seen. I have a fabric brush to clean them every once in a while to get the dust and dirt out. That seems to work well. Alcantra seats seem to develop a dark or smooth patch where the seat belt rubs against the seat so I purchased those fabric seat belt comfort guards and placed it in between the seat belt and the seat.
OCD - obsessive car detailer!
brianc is offline   Reply With Quote
Old 07-06-2012, 11:29 AM   #6
2pt5RS
Berz
Type III - Cleaning Alcantara® Leather
Alcantara® Ultra suede™, Ecsaine, Micro suede, etc) are not types of leather but are in fact in synthetic materials, it is made from extremely fine polyester microfibers (68% polyester and 32% urethane) it has the appearance and tactile feel similar to that of suede, and it may be incorrectly identified as such. Toray Industries' Ultra suede or Alcantara is finding application in seating as well as dash trimming, steering wheel covering and headliners in many high-end OEM automotive applications
Identifying characteristics - these materials are very soft to the touch and will scratch or scuff very easily.
The water-drop absorbency test- water drops will darken the surface and will remain dark or leave a water mark after drying.
Water absorbency rate – high, due to the potential damage caused by water foam cleaners are highly recommended
Well known for its use in top marque automobiles such as Aston Martin, BMW and Ferrari, this material is both hard wearing, luxurious and stylish. Suede is rarely used for automobile upholstery, however Nubuck or a synthetic known as Alcantara® Ultra suede™ is commonly found in sports luxury vehicles; on the steering wheel, armrests and seat inserts both for aesthetic purposes and grip (on the seats and steering wheel) and the headliner, it is highly absorbent, creating a texture similar to velvet, many people confuse this product with suede leather.
As a general rule when cleaning Nubuck, Alcantara ®, Ultra suede™, Ecsaine, Micro suede, etc you should only to use products specifically designed for this type of fabric. Avoid using a product designed for cleaning leather. It's also important to do a patch test before cleaning any fabric to make sure the colour or integrity of the fabric won't be damaged. To do this, apply your cleaning product to an inconspicuous area to see what the effect will be.
Use a napping brush to raise the pile and loosen / separate the fibres. Remove pilling with a single-sided razor blade and then apply a suitable cleaning solution on to an applicator pad and apply to one area at a time (do not over-wet the fabric) and do not use wet steam.
Localized stains can be treated with a d-limonene (citrus) based cleaner (P21S Total Auto Wash) ensure surface is dry before use by leaving window cracked/open or SONAX NTS7 Upholstery Cleaner for BMW, Porsche and Mercedes-Benz Alcantara materials. Avoid alcohol, strong solvents or spirit based cleaners (particularly perchloroethyene and trichlorethylene).
Weekly
Dust the fabric using a soft upholstery brush, and then vacuum. Then run a lightly damp micro fibre towel over the surface to remove any small dust particles.
Since the whole page is barely loading, I'll just post this.
Old 07-06-2012, 12:24 PM   #7
brianc
OCD
brianc's Avatar
I see they updated their website. Years ago it was much more primitive than that. They've also updated their cleaning and maintenance section.
Old 07-06-2012, 10:58 PM   #8
wallace03
wallace03's Avatar
Drives: WRB BRZ
i would imagine CG fabric guard is the same concept as 303 fabric guard. still kind of nervous
Old 07-07-2012, 09:49 AM   #9
bryansbestwax
Drives: black suv
all you can do is try a small test spot in an area that isn't as noticeable. The alcantara cleaner I have been using for a while and never an issue, its specifically for this material. I do a tonne of Subaru interiors in the spring, many of them STI so I see a lot of alcantara
Alcantara material? ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 13 06-03-2015 05:24 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
Rolex 24 hrs Maintenance Sale at AZP Installs. AZP Installs NY / NJ / CT / PA 0 01-26-2012 09:58 AM
AMT, Air Maintenance Technology 1660 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-28-2011 04:15 AM
