AP Sprint clicking noise when turning
Hi there,
Wondering if anyone else with the AP kit has had "clicking noises" when turning? Most noticeable at relatively low speeds at sharper turning angles - could it be combination of floating rotors, j-hooks, and piston angles when turning? Sounds like a metal-on-metal click, perhaps 2-4 times per revolution. Thanks!
#2 | |
Drives: '14 BRZ WRB
Drives: 2015 BRZ CWP
I don't have the AP kit buy I had a clicking noise with my Stoptech kit and found the noise coming from where the lines mount to the hard line on the fender wall. The clip from goodridge lines that I have that holds the line in there worked itself loose and when turning almost full lock left or right caused a click/tapping noise when turning.
Put new clips in that i had from an old stoptech kit and got rid of the noises. not sure if it helps, but could be a place to look. |
Turbo E85
Drives: 13 wrb brz
Check for anything making contact.
My sprint kit doesnt click andni tracked it 3 times with it so far since installation
Flex Fuel Turbo BRZ
@BRZtoni I'm wondering if it's related to wear on the rotor. It's just funny that I get noise on both sides now. Probably 8 track days on the set now.
Sent from my ONEPLUS A3000 using Tapatalk
Drives: 2017 BRZ
I'm pretty sure the Sprint does not have a floating setup... from their site:
That said, no noises from mine, but I probably abuse them far less. If it's a new noise, I'd suspect wear related or heat-cycle related. Inspect all fittings and fasteners. |
#9 | |
Turbo E85
Drives: 13 wrb brz
like the other poster said, check the rotor top hat maybe it got loose?
Flex Fuel Turbo BRZ
#10 |
Retorqued a couple of weeks ago but I realize now I only did 10ftlbs and not the 18 for the fixed style of the sprint rotors... woops. But no movement at 10ftlbs, likely none at 18 as well but will check.
#11 |
Drives: the white one
Did you solve this?
How do you have your brake lines routed? It could be rubbing on your wheel. A line rubbing on the wheel weight would make that clicking noise. If it is rubbing on your wheel, it is more than likely wearing out that one spot on your brake line, which could end up bad if it rubs all the way through
If you can't win a race, beat the person in front of you
#12 |
crew chief
Drives: Race car FR-S
we have that problem with the Racer-X lower control arm and AP sprint kit, when completety turned the lower ball joint makes contact with the disk, must not be a problem with the stock LCA but worth a check.
#13 | |
Drives: 13' BRZ
According to O'reilly's it also fits Subaru Forester, Impreza, and Outback. If you want "OEM" your local dealership should carry it as well. Just look up the year model and cross reference etc. BrakeBest Hardware & Hydraulics - Brake Hose Lock (Part #H1457-2) http://www.oreillyauto.com/site/c/de...0265&ppt=C0064 |
#14 |
Drives: 2016 FR-S
My guess is slightly uneven pad deposits on the rotors which make contact with pads when turning. I believe the AP calipers don't have pad tensioners so they can click.
| Clicking/cloncking from left front when turning wheels | cawith | Issues | Warranty | Recalls / TSB | 14 | 02-08-2019 06:14 AM |
| Wilwood BBK Clicking Noise | AlexK | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-24-2016 08:38 PM |
| Clicking noise from exhaust? | azynneo | Issues | Warranty | Recalls / TSB | 6 | 06-16-2015 03:05 PM |
| Clicking noise in engine bay | teddydoggy | Issues | Warranty | Recalls / TSB | 4 | 08-12-2013 05:15 AM |
| Clicking noise? Not crickets... | Laika | Issues | Warranty | Recalls / TSB | 4 | 10-18-2012 07:39 PM |
