Member of the year - 2016
Drives: Scion FRS
Consensus on changing whole transmission versus changing solenoids
Hey guys,
I hit a rock in the middle of the road going 40 mph on some of the mountain roads outside Portland. Afterwards, the CEL went on and the car only wanted to stay in third and fourth gear. I limped it over to a mechanic about 1 hour and half away in Portland. The damage is a smashed oil pan for the transmission and solenoids B and C completely smashed, also a smashed exhaust. I'm worried about long term damage to the transmission because i know there will be smashed bits now transitioning around the transmission during use. What do you guys think about changing the whole tranny instead? I can find one for around $800-1000 around here. I know that if i went the parts route, it would be around $400+ in parts. I also need to drive home to New York in two weeks, which is 2500+ mile journey, so i need the car to be reliable. It'll be still be taken to track days and events during its life as well... Also, don't tell me about manual swaps. I already thought it out, it would work if i was New York, but not here. Thanks.
Drives: Toyota 86 GTS
Driving it damaged for so long doesn't inspire any guarantees that other parts inside aren't damaged, even if you fix it.
I'd get a replacement, then see what it would take to fix the other one. |
I vote for a new transmission.
humfrz |
Drives: 2013 Asphalt FRS
If you smashed the solenoids I would replace the valve body.
Turn it into insurance pay the deductible. Of course if they want to give you a new trans cool but they will almost always opt for a repair and if there is problems later another repair....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
Junior
Drives: a car
I say new trans, then build the current one
not playing cards
Depending on your budget, a grand is worth the peace of mind. Like others have said, swap them but keep your original.
Unless the pan was smashed in deeply enough to carry the damage further, I'd bet money that when you do dive into it you will find the rest of it to be pristine. Have a safe trip home.
Undisputed El Presidente
Drives: Zenki 37J ZN6
I would do a new tranny just for the piece of mind
| Changing Automatic Transmission Fluid | euthqt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 06-01-2016 04:16 AM |
| changing brz lettering | c2yp7ic | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-13-2015 08:42 AM |
| Any consensus on best manual transmission fluid choice? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 05-01-2014 07:14 AM |
| changing the transmission of an fr-s from automatic to manual. | enjoi23 | Engine, Exhaust, Transmission | 55 | 08-23-2012 12:24 AM |
